Question about Fujitsu fi-5530C Scanner
Multiple sheets Scanner intermittently grabs multiple sheets in error
  • 81 Answers
You can try to clean the retard pad under the feed roll, but for best results you should replace it. Parts are readily available on the web. You should spend around $20 for the pad, and $50 for the feed roll. You may not need the roll. Examine it and see how the tread looks. These parts are easy to replace.
Posted on Feb 29, 2008
Hi, my canon ip2600 printer is grabbing multiple sheets of paper when printing instead of a single sheet at a time. It prints but some lines of print in the final result are to compressed to be almost...
the printer is grabbing multiple paper because the paper is stuck together in cold times the paper sticks together when you insert paper into the paper try try to make the papper loose
Mar 01, 2011 | Canon Pixma iP2600 Photo InkJet Printer
My Xerox 4150 keeps taking lots of blank pages through when printing multiple page documents sometimes 30 or 40 at a time
Two possible solutions to your problem.
If you are talking about grabbing more sheets than one from the tray, you need to make sure the tray guides are up flush against the paper.
If on the other hand you are talking about scanned/copied jobs, check the setting for your scanner, it may be set to letter size which is longer than A4, so the machine thinks it needs another sheet to complete the job causing a blank page to be sent.
Hope this helps
Jan 10, 2011 | Xerox WorkCentre 4150 Black and White...
Setup multiple spreadsheet pages
Do you mean to display multiple sheets at the same time? Please check out the solution provided below (this applies to Excel 2003)
1.) To view multiple sheets in the active workbook, click New Window on the Window menu. Switch to the new window, and then click a sheet you want to view. Repeat for each sheet you want to view.
2.) On the Window menu, click Arrange.
3.) Under Arrange, click the option you want.
To view sheets in only the active workbook, select the Windows of active workbook check box.
Apr 12, 2010 | Microsoft Excel for PC
My artisan 700 keeps pilling in multiple sheets and then jams.
hi there, il be glad to assist you.
If multiple pages feed at once, remove the paper from the tray, fan the edges to separate the sheets, then reload it. if Paper Jams Inside the Artisan 700 Series: Open the scanner. Remove the paper as shown, including any torn pieces. Squeeze the hooks and remove the cover inside the Artisan 700 Series. Remove the paper as shown, including any torn pieces Reattach the cover. Close the scanner. if after doing all of these still same issue persists, if the issue persists, call epson to get a replacement printer if the product is still 1 yr. from the date of purchase, if it is more than a year, most probably, thats out of warranty,
Feb 16, 2010 | Epson Artisan 700 InkJet Printer
When i fax multiple sheets, they stick together
The separator pad is probably toast.It is a little white or gray rubber pad on the scanner assy.If it is intact, clean it .If not it must be replaced
Mar 24, 2009 | HP 1050 Plain Paper Inkjet Fax
Canon DR-2080c - Replacing rollers
Check for a switch on the scanner that is made to feed single pages or multiple pages. If it is on single page it can multi jam all the time.
As far as the rollers go there is a pick up roller, separation roller, and a feed roller. You can clean them with rubbing alcohol to see if its indeed the tires that are bad. The exchange kit has all three tires in it that are user replaceable.
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
Sumproduct or conditional sumif with multiple criteria in vba code...
i'll just reply to your conditional sumif query.
yes, you can do multiple criteria query but with a matrix formula. you may look it up. nonetheless, here is how one would look like:
{=sum(if(range1=A x range2=B x range3=C, sum range))} note that x (multiplication) is used to denote intersection of the criteria
initially, you'll enter it as:
then, edit the cell (F2) and press ctrl+shift+enter for the brackets { } to appear.
Jun 27, 2008 | Microsoft Excel for PC
HP 6110 scanner wizard
What is the OS on both the computers ?
Jan 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
The rollers and retard pad need replaced.
The rollers are self explanitory, the retard pad is so named to retard the feed of multiple sheets of paper.
That is your problem.
Nov 07, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
Fujitsu fi-5530C Scanner Logo
192 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
