Question about Microsoft Xbox 360 Console
Internet i was trying to use my wireless network but it said falied on my ip adress i have never have to put in an ip adress
  • Anonymous Mar 01, 2008
    where do i find an ip address?
  • 3 Answers
All you have to is unplug the internet from the wall for 30 seconds and then plug it back in.
Posted on Mar 17, 2008
Hi, I bought a TP-Link TL-WA701ND (Wireless Lite N Access Point) today, and am having troubles getting it to work. The Quick Installation Quide gives directions for Windows operating systems XP and Vista...
You must setup manually your acces point. First go to control panel, under network and internet you'll find a task, view network status and tasks click on it and in next page go to change adapter settings, find local area connection and right click on it and go to properties, in next window highlight internet protocol tcp/ip then click on properties in next window click on use the folowing ip adress and write in ip adress box an ip from 192.168.1.2 to 192.168.1.253 at your choice in subnet mask box just leave 255.255.255.0 (this apear when you click in these box). Now connect your acces point to the computer via network cable. Then open your internet browser and type in adress box http://192.168.1.254 and hit enter, a pop up will apear and ask for user name and password, write admin in both boxes user and password and hit enter, after that you will be able to manually configure your acces point and setup a name and password for your wireless network, change your user and password for acces your device. Good luck!
Mar 23, 2011 | ASI TPL WL TLWA701ND 150Mbps AP Wireless...
D-Link 2100 AP is working in Wireless Client mode. It is connected to home network with cat5 cable. The remote ADSL modem is 192.168.1.1 and DHCP on. The first computer in the network obtains IP and...
Check in your router to see if your router is set up to be a DHCP Server. If your router and adsl are both set up to be DHCP servers, sometimes they will fight with each other and some computers seem to have problems getting adresses from this kind of setup. Make sure that only one is set up to give out adresses, then check on your second computer to make sure that it is set to obtain adress automaticaly. If someone has set a manual adress in that computer that is not on the same subnet as the router, they will not comunicate. If this does not solve your problem, try putting in manual adresses into both computers: IE 192.168.1.2, subnet mask 255.255.255.0, Default gateway 192.168.1.1 in the first, and 192.168.1.3 in the second with the same subnet and default gateway,
Nov 24, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
I have sign in HP photosmart to internet wireless connection and is notconnecting but still searching What do I do now.
connect it with ethernet cable to router. then press setup button scroll to netwrok setup press ok. scroll to view netwrok settings or print netwrok settings press ok. scroll to print netwrok configuration page. get ip adress. open internet explorer type ip adress in adress bar at top. then hit enter. it will open pritner ews page. at top click on networking. then on top left corner under connectivity click on wireless then click on ipv4 configurations. under that click on manuall and put same ip address and default gateways and subnet mask that u see on netwrok configuration page. adn hit apply. then go to netwroking tab and look for wireless setup wizard. click on that run wireless setup wizard from computer. it will successfully connect pritner to netwrok. then disconnect ethernet cable and turn on wireless radio. ur pritner is ready to go. print one more netwrok configuration page to check if u r getting same ip address after disconnecting ethernet. and then try to open ews of pritner again from internet explorer by putting ip address in address bar. if it is successfully opening page ur pritner is connectd to network.
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Unable to configure router. I am using Netgear router, WGR614
first enter to your network connections in control panel, double click local area network, properties, internet protocol(TCP/IP), and tick Obtain an IP adress....Obtain DNS server..... and after that ok...ok..ok.
Now open an internet explorer window and type in the adress bar 192.168.1.1 and press enter . if you are asked for username or password try writing admin on both. good luck!
Oct 27, 2009 | NetGear WGR614 Wireless Router
Can't get network connection to work.
Are you trying to connect to the Internet using a wireless router or vai a network cable?
Have you got an Internet Service Provider and does your computer have trouble connecting to the Internet?
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
Wireless shows connection,but will not connect.
This kind of problem occur due to dhcp disable in the wireless router for the security purpose. So try to give the ip adress manually by right clicking on the wireless and give the ip adress of the same range in which your network in working e.g 192.168.1.0 is the range of your ip addresses so please select the ip which is not been used by any other computer and than in default gateway enter the ip address of you wireless router and you will be able to access the internet on your system.
Dec 01, 2008 | Linksys Wireless-G WRT54GS Router...
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Getting an ip connection
You have to put in the SSID (the name of your network, this one you put in the router configuration) of your router to which you are trying to get the ip from, into the wireless NIC card configuration to which you are trying to get the ip from.
Make sure that you have installed the software that came with the wireless NIC card.
Hope that helped!
Thanks
Dec 17, 2007 | ASUS WL-100G 802.11g/b Wireless Adapter
Unable to open internet page
let you router allocate the ip addresses manually by enabling DHCP and restart the router,and remove the usb adapter from the usb port and reconnect it, but when you right click on the taskbar on the little pc icons for your connection click enable WZC windows wireless Zero configuration as this will dissable the software you got with the usb adapter and hopefully make the connection more stable, but ensure you have a strong signal.
Jun 01, 2007 | U.S. Robotics MAXg USR5421 802.11g/b...
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
