Question about Panasonic PT-47WX49 47" Rear Projection Television
Split screen question
Do I need to have a VCR for the split screen option to work on my TV? I curently have Tivo, Sony DVD surround sound system and DirectV box hooked up to my TV
    President:
  • Panasonic Master
  • 1,779 Answers
Only if you have 1 Ant input, if you have ant 1 & 2 then you don't need a vcr for split screen.
Posted on Feb 29, 2008
Dvd player is playing a vertical split screen
If the TV does the same with two different DVD players, it must be a menu setting on the TV. Look through the TV menu options.
Jul 24, 2013 | Panasonic DVD-RP56 DVD Player
I want to plug in a game console but my tv will not show all the input options. Simply has "TV" Video" and Cable... It all runs through surround sound, so I'm wondering does the surround...
connect video and audio to tv - when it works, split audio to both units (tv and surround system), reason for it might be ground problems or sync failure
Feb 07, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
INSTRUCTIONS ON HOW TO hook up surround system to a flat screen t.v..tv is a sharp, and surround system isYamaha, and tv is connected to a dvd and vcr system
Use the Audio Output jacks Red/White from the Tv to the Tv Audio In on the Yamaha. If the audio out is being used from the tv now then go to Best Buy, Radio Shack and get a Y-adapter (rca jack type) with Single Male--Double Female. That will split off the audio coming out of the tv.
Dec 06, 2010 | Televison & Video
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=DAVC700&LOC=3
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Ah split screen just another way of getting two picture in one screen, or sport for he and Opra for her.
Fisrt you must understand what split screen is, it is taking two information from different source and sending the info to the micro to devide the info for two seperat image.
Well something like that but I know you were inpress,
Yes you can. Take the main source you or using I would say the TV box in cable connection or av1 and then your DVD or and VCR to source av2 or 3. When presing split screen or pip you will get one screen showing the main source your tv box and the second your dvd (or VCR) in the source input solector you should be able to change the second amage input with input solector and the tv box change the other.
Oh what a butiful life aint it.
Try this with 7 different source, Cable, satelite, fta, dvd, camera, gaming sytem, and computor,... well that another chapter.
What about Bob
Feb 29, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Surround sound hook up
av/out on tv to av/in on vcr / av/out on vcr to av/in on home theater pls rank
Jan 23, 2008 | Televison & Video
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Oct 16, 2006 | Sony KV-32S25 32" TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
100 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
