Question about HP P5302M Computer Speakers
The speakers don't work anymore...
I have cleaned out my computer after a crash and now the computer no longer thinks I have speakers, I have tried varied methods of getting them to work but only once did any sound issue forth from them and even then the computer says nothing happened. Help please.
    Guru:
  • 147 Answers
TheLastStraw,
Pardon the pun, but it "sounds" like you need a new sound card. I recommend TigerDirect for quality parts, service, and shipping.
Please let me know if this helps. Good luck!
Posted on Feb 29, 2008
I don't have any sound on my computer's internal speakers or my headphones after installing windows 7 pro on my averatec a2 all in one pc, can anyone help me?
You probably just need to install some fresh RealTek drivers. Normally, Windows Update should address this problem but if it doesn't then you can find the drivers you need here:
http://www.realtek.com.tw/downloads/
And choose the High Definition Audio drivers for 64 bits Windows 7.
Dec 19, 2012 | Computers & Internet
SPEAKERS DON'T WORK WHEN I PLUG THEM IN.
desktop or laptop computer ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 19, 2012 | Audio Players & Recorders
Micro innovation speaker model# MM610D will not turn on
This Is A Huge Problem, Why Don't You Try Reconnecting The
Wires To The System And Run A Reset On It.
Good Luck,
Kevin
Aug 24, 2012 | Micro Innovations MM600D Computer Speakers
The speakers don't work at all. The blue light goes on fine, but there's no sound. They used to work fine with my iPod and iPhone, but not anymore.
Hi, Have they been turned off?
These speakers have a habit of setting their volume level to zero if the power is removed.
At the bottom of the right-hand speaker you should see some tiny volume up/down buttons.
Try pressing the up and see what happens.
May 05, 2011 | Harman Kardon Harmon Kardon SoundStick II...
My speakers are not working. When I open itunes it says. iTunes has detected a problem with your audio configuration audio/video playback may not operate properly. I recently used some software 'Magix...
http://support.creative.com/
This is Creative's support link. The speakers you have are Dell. Do you have a sound card installed? If you have a speaker icon in your taskbar, lower right of screen, does it have a red X? Right click on it then, click on playback devices. A window should open with your device. Does anything show up and if it does does it show it "working"? Right click on it and a window should open and you should see "enable" or "disable", if it shows enable, click on that and exit. If you are still ahving problems with this let me know at "add a comment"
Dave
Mar 21, 2011 | Dell 5650 Computer Speakers
No sound
You have to install the drivers for the speakers. If you dont have them , then go to the manufacture website and download the drivers selecting the right operating system
May 18, 2010 | Insignia 2.0 Speaker System (2-Piece)
Sound?? Inspiron 1100 problem
Please varify that the sound is not set to mute.....check the volume control dial on the side of the notbook where the sound jacks are...verify its not set to minimum....
do you just rely on your pc speakers have you tried with an external speaker.....
keep me posted....and please don't forget to vote if this works for you
Cheers!
Nov 13, 2008 | Dell Inspiron 1100 Notebook
Need driver for Altec Lansing 221 Operating Sys Vista
The independent site providing the software is not working anymore, and the 221 are not anymore in factory product page. I think the best thing to do is contacting directly Altec Lansing, and asking a replacement cd.
Regards
Apr 06, 2008 | Altec Lansing 221 Computer Speakers
HP P5302M Computer Speakers Logo
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
