Scan lines at top of screen
I have been told it is a split screen.. the problem is that there is a line of flashing lightand there are scan lis that show a reversed picture over the original picture.. when the coclor is dark or black there is no scan lines. when there is a light color the lines are prominate. Can this be fixed with the internal diagnose codes?
  • JoedyJr Mar 01, 2008
    I have looked for this answer for sometime. thanks for getting right back to me. I was also wondering what would happen if I continued to run my set. I had a friend who had this same problem and it did exactley as you said again thanks Joe
    Scholar:
  • 133 Answers
Not likely . Sound like you have vertical overscan problem due to a capacitor or two going weak. If you continue to run the tv with this as your problem your vertical section could over heat making the output IC fail causing a flat line going side to side . Good luck
Posted on Mar 01, 2008
Plasma inverter
If you only have half of a picture, usually top or bottom, then there is a problem with the upper or lower scan buffers. What is the make and model number and is it split top to bottom?
Feb 07, 2018 | Fujitsu Siemens Televison & Video
Compaq C700 laptop screen shows horizontal lines and the screen seems to be split into several sections
The LCD screen is faulty and will need to be replaced, go to www.ebay.com Type: make and model refine search to screen, first! hook a spare monitor to the video output usually on the back, if picture okay! the above mentioned needs to be changed, but! if both show the same symptom it is the video graphics card that is part of the motherboard.
Apr 19, 2012 | Computers & Internet
Our Phillips flat screen TV picture is split down the middle vertically. One side shows a mirror image of the other side, and then sometimes one side is a lighter shade than the other, when it is full...
This may be due to a faulty Timing Control board (TCON board). I had a similar problem with my Samsung LCD TV picture being split vertically down the middle. The image on both halves appeared fuzzy and in reverse (mirror) including the menus. I replaced the TCON board and the problem was resolved.
Aug 18, 2011 | Televison & Video
Panasonic camera md 9000 it has reset problem
you have problem with socket cylinder head..you can't repair this problem, you must bring camera to panasonic service center
Jul 01, 2009 | Panasonic NV-MD9000EN Mini DV Digital...
I get sound but no picture from my DVD player.
Check if you don´t activate the progresive scan function or video sistem
Apr 23, 2009 | Samsung DVD-V5500 DVD Player/VCR
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Video Issue
It sounds like you have the "progressive scan" mode enabled. This changes the order that the scan lines (each horizontal line) is sent to your TV. When this setting doesn't match what your TV expects, you get this effect.
Apr 16, 2007 | GoVideo VR3840 DVD Recorder/VCR
Fuji Finepix split screen
If the picture taken from digicam are ok when viewed from a computer, the lcd viewer has a loose connection or defective already, if you can open your unit, try to disconnect and reconnect the lcd flexwire inside.
Oct 15, 2006 | Fuji FinePix S2 Pro Digital Camera
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
