I refilled my ink on my lexmark 2600 but it says its empty
According to your problem it seems your cartridge has been damaged or choked so change your cartridge. Because some times when we use refilled cartridge, Ink goes dry and printer's sensor can not sense the ink.
Regards
Ashly
Hi there
If you refilled the inks your self , lexmak do not reset on refills got to have they new inks sorry.
SOURCE: refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
SOURCE: need to reset ink levels on printer (lexmark 2600)
Hi
It is the chips on the inks that make it shore empty nothing you can do about it.
But I have found this bit of read up on the internet forum Gave it a go may work if it works come back let us know so I can pass it on to others Thanks.
1 Take a small pice of clear tape. Try covering one of the outside vertical row of contacts at thr front of the cartridge. Re-insert it and it shoudl "fool" the printer into thinking it is a new cartridge. It works for my Lexmark 2600 series all in one.
2 Use clear tape over left hand row of sensors on front of cartridge and re-insert. ink now shows with question mark but reads as full and prints fine.
3 I had fully covered the contacts because it was the full length of my Scotch tape. It did not work. I went back and re-read thread, wiped the contacts the computer was telling me, took off the strip and put on just a sliver covering the left vertical side of the contact only. It worked! Yippee! Thanks a million!
Go to this website to see all
You can go to this link to see all the read up about it.
http://www.fixyourownprinter.com/forums/inkjet/35235
I not have this printer myself so I not can say if it works or not.
All The Best Hope it works for you
