Question about Lexmark X4270 All-In-One InkJet Printer
Doesn't have dial tone
My Lexmark 4200 doesn't have a dialtone Ican't send or receive one. I find no place to connect the phone line to the tower
  • 106 Answers
From the behind of the your fax you have a conection jack ,there is a name in the top of conector "line" this is a 6/4 telephone conector.
Posted on Feb 29, 2008
Why no dial tone. Only static?
Check the phone line were it comes into the house there is usually a point where the phone connection from the the TELCO outside wires connects to the inside wiring.
Remove the inside wiring and test the wiring that is on the TELCO side. If you get dialtone the trouble is in the inside wire. If you don't get dialtone call TELCO
Aug 26, 2014 | Lands Phones
I have no dial tone on my fax machine and i cant send or receive faxes
Remove the phone line from the back of the fax and connect a standard phone (not a business PABX or PAX system phone) to the line. Ensure dialtone is available. (Make sure in doing this that you are also testing the cable from the phone socket to the fax). If no dialtone, replace cable or fix line.
Check that the line is connected to the 'line' port on the fax, not the 'phone' port.
If still no dial tone, it may be modem fault (in the fax). Seek specialist attention.
Feb 12, 2010 | HP 640 Inkjet Fax Machine
Lately every call I get I lose and receive a dial tone I am with bell but they say it is my phone possibly a software issue
Well, interesting part is, your phone doesn't create the dial tone sound.
If your call is ending, then you hear the dialtone, I would suspect a problem with a particular tower. If it happens all the time and in multiple areas, then all bets are off.
Nov 02, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
No dial tone on my Lexmark X4270
There are two outlets in the back where you plug in your phone line. I had the same problem when I
was plugged into the far left plug (as you are facing the front of the all in one). I switched to the other
outlet and it worked fine. But still once in a while it seems to loosen up and I have to push it back in
farther. Today I got a dialtone but could not send a fax. I got a dialtone but still wouldn't send. So I
checked the outlet and sure enough, it was just loose enough to prevent the machine from registering
the fax number, but connected enough to get a dialtone.....go figure. Good luck
Apr 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Fax not going out/coming in
connect a phone with 4521 in the back side jack of phoneout,
for outgoing fax
place original in the adf or glass for fax
Press hookdial and dial your sending fax number in 4521 after number dialing pull the phone handset to ear when you leason fax tone from the dialing number press start button to send fax.
for incoming fax (in not automoated)
press hook dial and press start to receive
Mar 01, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Can't receive or send fax on my lexmark X4270
In this case first we need to chk whether there is any dial tone on ur fax machine for that u need to Hit the Options button till u find an option saying On Hook Dial now hit select and it should give u a dial tone if it doesnt check the Phone Line Connections........... If it gives u a dial tone........... Unplug the Power Supply from the Printer........ Press and hold the Stop/Clear button and while holding the Stop/Clear button insert the Power Supply back to the Printer........ It will say clearing and then display a page where u need to Selct ur Country and the other details........ and as soon as this is done u can send and recieve faxes....... Thanku
Jan 12, 2009 | Lexmark X4270 All-In-One InkJet Printer
Not able to fax due to no dialtone?
Check the phone line with a regular phone and listen for a dial-tone.
Jan 06, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Feb 15, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X4270 All-In-One InkJet Printer Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
