Question about Freezers
Freezer rs21dgrs water not working???
Please help water dispenser not working
  • Ron Coons
    Ron Coons May 11, 2010
    model and manufactue would be helpful
    Genius:
  • 1,019 Answers
Purchase A premium Solution Package For $19.99.
One of our technical Wizards, will Sort This Problem Out For you In 1 Hour. ** Time Of Day Depending**
@ $19.99 Or £10.00 G.B.P
You Can,t lose.
Mike @ Compurepair.
Thankyou For Using FIXYA.
Posted on Mar 01, 2008
FGHB2844LF water dispenser not working
Turn the temp down on the refrigerator side but not below freezing. Some frigs have a "trap" set up for the water dispenser. its located behind a panel in the frig and it is there to help chill the water before it dispenses. if the frig setting is too cold then it can freeze the water .
Dec 08, 2013 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
KENMORE SIDE BY SIDE, MODEL 106.51562103 NOT GETTING WATER INTO FREEZER DISPENSER
Hello and sorry to hear about your problem.
90% of the time you will have 2 issues, the water lever switch has failed or the main water inlet valve has failed. I suggest you call a service company.
I have tried to help you. So please help me and Vote/Rate this response. Thanks and good luck.
If you live in the Denver Area, I can help you.
Jan 04, 2011 | Kenmore Freezers
Daewoo frnu20da Water/ice dispenser supply
Makes no sense, you would be back and forth every twenty minutes.
Jul 23, 2010 | Freezers
Bosch upright freezer ice maker and water dispenser just stopped working
hello many times when the water and ice stop working you are not getting water to your freezer. so a few things to check if you have a water filter behind the freezer check for a blocked filter next. where the water line hooks up to the freezer there is usually a screen . turn the water off and remove the water line and check the screen if that s all ok it maybe the water solenoid hope this helps if not get back with me pls jason
Jun 09, 2010 | Bosch Freezer B24ID80SRS Stainless Steel
LG LRSC26923TT, water dispenser not working
I have a LG GRP207TUJA side by side freezer, which has a water,ice,crushed ice dispenser. There is a button to select which mode of dispenser. The freezer just appears to be cycling through all the selections all by itself and make the bleeping noise as it moves from one selection to another...any ideas
Sep 15, 2009 | Freezers
Frigidaire won't make ice & dispenses only about 4 oz. cold water
Water frozen in the freezer supply line - you need to thaw out the freezer. About six hours, door open, turn freezer OFF. You'll need a cooler with dry ice for your frozen food. 99% certain it'll work after that.
May 26, 2009 | Freezers
Icemaker and Water Dispenser won't dispense either....
Do as the guy above suggested? This more than likely is the problem. It is not expensive to replace. The question is, can you do it? If you can check to see if the valves are bad, buy new ones and try to do it yourself. If you are uncomfortable, then get a tech or a friend to help you. At least your frig is still working.
Feb 16, 2009 | Freezers
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer is not making ice
PULL THE FRONT COVER OFF OF THE ICE MAKER AND CHECK THE PLASTIC GEAR ON THE FRONT OF THE CONTROL. THE CENTER OF THE GEAR HAS TWO PLASTIC TABS THAT HOLD THE GEAR IN PLACE. IF ONE OF THE TABS IS BROKEN OR MISSING, THE CONTROL OR THE WHOLE ICE MAKER NEED TO BE REPLACED.
CHECK THE ICEMAKER TO SEE IF THERE IS WATER OR ICE IN THE MOULD. IF NO WATER OR ICE, THE FILL TUBE IN THE BACK WALL MAY BE FROZEN OFF. REMOVE THE FILL TUBE AND CLEAR IT OF ANY OBSTRUCTION. YOU CAN ALSO USE A HAIR DRYER TO MELT OUT ANY ICE FROM THE FILL TUBE. THE OTHER POSSIBLITY IS A BAD WATER VALVE. THE WATER VALVE HAS TWO OUTPUTS, ONE FOR THE DISPENSER AND ANOTHER FOR THE ICE MAKER.
Mar 31, 2008 | Freezers
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Freezers Logo
83 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
