Question about Whirlpool AWM5145/2 Front Load Washer
MACHINE WONT WORK, NO WATER GOING IN
When I click on a programm it clicks once, no water going in and the dial stops moving. If I put the dial on drain it sounds if it is draining, I left the machiine off for a while and then tried it again. It worked briefly so I know it is not the belt as the drum turned and water went in.
  • Fims Nov 04, 2008
    Our machine will go through the whole cycle but will not take in any water.
    Any ideas?
  • Whirlpool Master
  • 5,568 Answers
Water flow is controlled (almost always) by an electrically controlled mixing valve generally part of the attachment points for your hoses.
Sometimes one can hear a slight 'hum' caused by the valve's coil if it is receiving control voltage.
These are simple devices not hard to replace and if one shops a little, not very costly either.
Check to see if you have a Johnstone Supply in your area. They sell to the trade but I have never been turned down as a private buyer.
It is also possible that screens at one or both ends of the hose are clogged with silt.
Check those first.
Posted on Aug 24, 2008
Error code E20
Turn the dial to off.
Press and hold the start pause and nearest option button to it.
Whilst holding them, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons.
Now turn the dial slowly through each position, stop and position 10 (9 clicks after letting go of the buttons) and note the error code displayed.
Continue turning the dial until you get to off.
Now turn to any programme, then, turn to off again.
Finally, turn to a programme and try the machine.
(It is very important that you turn to Off, a programme and then Off again).
Let me have the error code you retrieved if the appliance still doesn't work.
Oct 14, 2012 | Electrolux Washing Machines
Problem with candy dishwasher model CSF 456M.
hi it may need a new inlet valve,can you hear a humming sound when its due to fill.or is it doing nothing.if its not humming change the valve,also these dishwashers are well known for overheating and sticking on cycle.
Jun 01, 2010 | Dishwashers
Dial keeps clicking around wont select a cycle, it was stopped mid cycle by accident then we tried to start at a new cycle ,since then the dial is costantly going around and the machine is full of water.
the washer is trying to reset its self. pull the washer out put the waste pipe to floor level to empty the water <not no your floor > plumb it back in then turn it on and it will sort its self out
Jun 21, 2009 | Washing Machines
Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Apr 11, 2009 | Washing Machines
My indesit washer/dryer model w10 ,is not working.the programme dial keeps cliking round wont start a programme or take in water.
probably a main module fault but worth while checking for continuity thro the heater and that the pump and filter are ok. the idea is that when a fault is detected, the dial will click round indicating a fault but usually it is the module itself. expensive part. not worth repair
Jul 04, 2008 | Indesit Washing Machines
Programme dial again
yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
Dec 18, 2007 | Hotpoint BWM12 Front Load Washer
Timer clicks arround and arround
My Belling integrated washing machine will not stop at the end of the cycle. My partner had accidently moved the dial during mid-cycle. We have tried to reset the machine by turning it off and then moving the dial around to the stop section of the dial. However when we turn it back on it waits for a while and then continues to click around with starting any cycle. Can anyone help? Thanks.
Jul 02, 2007 | Belling SGE12X Front Load Washer / Dryer
Whirlpool AWM5145/2 Front Load Washer Logo
259 people viewed this question
Dan Webster
Dan Webster
Sal De
