Motherboards
Problem for Motherboards
Generic problem for all Motherboards
I accidently set my boot menu to zero val...
By JOhn190 on Feb 29, 2008
I went to my computer and opened system properties and then cliked on advance tab then went to start up and recovery settings and be damned if I didn't assign zero value to the wrong one can you talk me out of this crazy dumb mistake il never do it again ?
Comments:
Mar 01, 2008
- Im Not Sure I explained my problem correctly
I installed win xp and used the recover previous version already on the hard drive.
It worked great I had it Actvation all done and every thing no Problem
Then I decided to elimanate the computer from pauseing at boot up and waiting 20 seconds to boot on into windows at this point ther were 2 choices " Windows " ( as one choice)
and another was "windows Xp" .
So i decide to go into my computer ,then properties , then Advance settings Tab then I set the zero value to both
choices under "Time to display list of operating sys "
"Time to display recovery options when needed"
Now when I try to boot it just start over and over I can't even do another clwean install I can't boot into my operating system now I hope this explains my problem better I do Thank You for your help JOhn190
Mar 04, 2008
- Thanks I appreciate evetry thing fine now
Best Solution
posted on Feb 29, 2008
Very Helpful)
Matt UK
Rank: Guru
Rating: 89%, 135 votes
You don't say which setting you have 'assigned a zero value to', but the default settings are as follows:
Default operating system - Fortunately you couldn't have deleted anything here. Just make sure it is set to the OS of your choice (Chances are there will only be the one).
Time to display list... and time to display recovery... - Both should be 30 seconds (for XP and Vista). By default, both are ticked in XP, only time to display list is ticked in Vista.
If you hit the edit button (XP only) your boot file should look something like this (upper/lower case is not important, neither is the exact order):
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Under the system failure section, tick everything.
Default for XP is small memory dump (64 KB), for Vista kernal memory dump.
Dump directory -
XP default is: %SystemRoot%\Minidump
Vista default is: %SystemRoot%\MWMORY.DMP
Do you REALLY promise you'll never do it again??? :-)
Matt
Comments:
Mar 01, 2008
- I understand your problem now!
Do you have a genuine XP disc or is it an OEM product recovery disc? The following will work with a genuine disc, but I can't say for sure about a recovery version...
Press delete while the PC is POSTing (just after power-on) to enter the BIOS settings and change the boot sequence so that the 1st boot device is the CD not the hard-drive.
Insert your CD and re-boot. From here you will have the option to carry out a new installation. As part of the install procedure, there is an option to delete an existing partition. You might be able to get away with just deleting one and not actually carrying out a fresh install. Delete one, and then re-boot to see if it's worked (you'll have to remove the CD or change the boot sequence back to hard-drive 1st before you do).
Alternatively, it might be easier to just delete all the exisiting partitions on the disc, reformat and carry out a fresh install.
Let me know how you get on.
Matt.
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
Mobo Samsung Harappa-12 can I have a manual pls? pdf or something my email add is... (More)
Answer
asrock k7vt4a pro if computer needs to reboot for software updates, it stalls on bootup, gives... (More)
Answer
no he podido formatear por unidad de DVD Porque sale un aviso verificando DMI. Le instale DD de 160... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
