Question about Marvin W.B. 5460 Quartz Humidifier/Heater
Thermostat control knob
Mine is broken and I can not find where to buy a new one. Thanks
  • Anonymous Nov 02, 2008
    Thermo control knob got hot and melted the plastic case. The unit still heats fine but i feel it unsafe to use without replacing themostat control knob.
  • rer0628 Jan 05, 2009
    thermastat controll melted on my 5460 quartz heater and i need to replace it along with the plastic knob. where to purchase?
    Scholar:
  • 79 Answers
(937) 653-7131 is the phone number of W B Marvin, according to my Google search. They should be able to help you get a new knob.
Posted on Mar 22, 2008
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
The turning mechanism on my triton ivory 4 has broken. The piece of plastic that sit in the cog to turn the power on has broken off. How do i get this repaired?
Hi, just had the same problem if you carefully remove both knobs and swop them over as the bottom knob does not require the T piece.If you get some thin plastic and gently prise each tab out enough to insert the wedges it will pull out. Hope this helps.
Jan 23, 2011 | Home
I have a u2-1887. the speed control knob has broken off. i need a new speed control switch and knob
SAME THING HAPPENED TO MINE...THE SWITCH BROKE APART IN PIECES...WHERE CAN YOU GET ANOTHER SWITCH?
Oct 12, 2010 | Patton U2-1887HO Floor / Box Fan
I need to know about the part that clips off that holds the air vent, a/c controls, and radio. Mine was broken into and the radio was stolen and the a/c controls behind the clip are broken and I can only...
you should be able to get the replacement parts from a dealer, from your description you should only need the radio/ac bezel and the ac control knobs.
Mar 12, 2010 | 2001 Dodge Neon
Where on line can I buy a new knob and cable since mine broke off
Go to your local wrecking yard--if they don't have one, they can find one.
Sep 19, 2009 | 2002 Mitsubishi Lancer
Broiler turns on all by itself. what can I do?
Hi, maybe your knob is broken, and it look as if it's off, remove knob and manually turn off , or you could have a faulty thermostat, or faulty circuit board, if knob is broken, you are smart, you can buy one and replace, if faulty thermostat or circuit board, you will need mechanic to check. good luck.
Aug 05, 2009 | Amana AER5715QAS Electric Kitchen Range
Broken control knob
go to a used appliance store, they have tons of those things!
Jul 24, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Hotpoint FFA80 Freezer Fan stopped working
This information may help you - it could be the fan motor itself by the way.
Servicing the Thermostat Control
©2006 Publications International, Ltd.
Thermostat controls regulate the temperature of the refrigerator
and freezer. Remove the control panel to reach the controls.
The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
Step 1:
If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Servicing the Evaporator Fan
In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary
May 09, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
No heat 2005 highlander
try pulling off the temp. control knob and tightening the shaft nut.
Dec 21, 2008 | 2005 Toyota Highlander
Broken knob
you can probably get a substitute knob from radio shack - replacement knobs. it may not have the markings you desire but at least you'll have a knob you can rotate.
Dec 25, 2007 | Crock Pots & Slow Cookers
Heating & Cooling Logo
244 people viewed this question
Top Marvin Heating & Cooling Experts
Oloyede Monsuru
Tom Chichester
Thomas Woodburn
Thomas Woodburn
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
