Question about RCA P52926 52" Rear Projection Television
Rear Projection TV P52770EB
Have a RCA rear projection TV P52770EB, made clicking noise and shut off, will not turn back on.
  • RustyfromLA Oct 19, 2008
    tv will not turn on- when plugged to the AC outlet there is a popping sound and I can see like a flash coming from the back
I CANNOT GET THE VOLUMN ON
Posted on Sep 06, 2008
    Scholar:
  • 133 Answers
You could have a few problems . If the front display light flashes only it could be you need a new deflection module . Also the HV block may be bad with it . If you have no front display light when you turn it on it could be the above problem or the signal board could be bad . The signal board would cost the most to get repaired due to it costs more. You would need a meter to check certain testing points to confirm which module is bad . Or call around to see who has the cheapest rate on an estimate to check out your tv. deflection board and hv block est $250 to $300. Signal board $300 to $350. Maybe more if you had a service call if you could not take it to a repair shop. Good luck
Posted on Mar 04, 2008
Where are the convergence chips on a RCA P52770eb
Your model has one IC which powers the convergence circuits. Its on the small Convergence power board attached to the heat sink STK730-130 I am attaching a pic of that board for youslinteriors_23.jpg
Aug 24, 2011 | RCA P52960 52" Rear Projection Television
I have a 2006 55" RCA rear projection TV that shut
vincevocsalo,
If your unit does not have a convergence menu now, you have a classic RCA convergence problem. I have a tip at
http://www.fixya.com/support/r5119668-fix_convergence_problems_rca_chassis
which explains the problem, how to repair it and where to get the parts and information to do it.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 01, 2011 | RCA P55000 55" Rear Projection Television
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
Power will not come on for a rca p52720lv tv>
Power will not come on for rca p52770EB tv. I used to hard time to turn it on. Now it is dead.
Sep 13, 2009 | RCA P52926 52" Rear Projection Television
Rca p52770eb wont come on sparks in the back about 2 inches from the power cord inside the tv
On some of the RCA televisions, the Hi Volt transformer will go bad and make a sizzling or popping sound. Most often, it will smell burnt when this happens.
Jul 17, 2009 | RCA P52926 52" Rear Projection Television
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Mar 29, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA P46920 TV will not turn on, it makes a beeping noise.
Shorted horizontial output transistor q14401 -I think- and bad flyback transformer(high voltage transformer).The noise is the power supply starting and shutting down very quickly because of the shorted transistor.Very common problem,but some of the flybacks are no longer available from RCA.Sometimes you can use generic but questionable life on some of these.
Jan 11, 2009 | RCA P46921 46" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
126 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
