Question about Asko 24 in. D3530FI Built-in Dishwasher
Asko d3530 dishwasher
How do we remove the upper basket of the dishwasher
  • 351 Answers
Theres two plastic clips at the front of the rails,turn them to the side and the basket will come out
Posted on Mar 02, 2008
Water inlet fault
Does it fill water at all? If not, the water valve is defective. If it fills, but then stops, it may be possible to program it to fill on time, instead of volume.
Oct 10, 2013 | Asko 24 in. D3530 Stainless Steel...
Not cleaning upper rack
check that the upper basket is the correct one for the unit. some one may have just put in a basket to sell it
Jun 01, 2013 | Asko Dishwashers
Perhaps a repair service that can actually see it might have a suggestion .
Aug 03, 2017 | Asko Dishwashers
Asko D3530 Dishwasher Water Inlet Fault
I did research on the net and asko mention a special settings menu in the pdf manuals available
you can download a manual but there is a reference to water not entering the washer in the manual and how to trouble shoot it
Pressure pumps deliver water at pressures from 35 psi to 60 psi and if you have checked all of the slow fill reasons , maybe checking the on/off pressure switch for the pump would be a place to investigate
the machine will start when the water has reached the level set
anyway go google and type in - workshop manual for asko dishwasher model d3530 --and download a pdf version to read
Jun 08, 2017 | Dishwashers
I have a Asko D3530 and the top basket isn't washing properly but in my menu section it doesn't come up upper basket wash anymore?? If someone could tell me how to get that option back that wo
Keep the Program button pressed until you see wash programs like Auto or Normal displayed. This should get rid of the Lower basket program.
Manual is available from here
Jun 27, 2012 | Asko 24 in. D3530 Stainless Steel...
I have an asko D3530 dishwasher. I'm getting an error message "water inlet failed". The manual says to check the inlet valve. Where is that?
Where you connect the water line from your house to the dishwasher you will find the waterline goes into a plastic body with an electrical wiring harness connected to it. You will have to take the panel off the back of the dishwasher at the water in line to see it. It is just an open/close electrical valve to control water flow
Jan 19, 2011 | Asko Dishwashers
I have a old Asko Dishwasher. It works perfectly. However at times at the end of the wash cycle the soap remains in the dispenser. This happens half the time.
Put less soap in. Your wash will be fine with less soap. We have same problem. MARK: do not have tall objects underneath that will stop upper rotor from spinning. Also objects in upper basket kan penetrate and stop uppper rotor from spinning. Using less soap works for us.
Mar 09, 2010 | Asko 24 in. D3450 Dishwasher
Change the lightbulb in a d3530
Called the manufacturer direct and saved $$$ by not using your site!
Jan 24, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Asko D3250 Bottom arm not moving
Check that the diverter motor above the wash motor is working and that you havent selected upper basket wash only,could still be a blockage in the lwr arm assy
Nov 17, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 24 in. D3530FI Built-in Dishwasher Logo
324 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
