Polar F11 Heart Rate Monitor Logo
Posted on Feb 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What battery is used in the wrist unit of the Polar F11
I want to change the battery myself.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
374
Points
Send it to an authorized Polar repair tech. Watch shops won't replace the seal and your watch will leak. The battery is only $12.95 at an auth. repair facility. I just had to and it was a snap.
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Feb 23, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1290894
Points
7081
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
How do you reset cardio track watch
u may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions
    • 1 Press any button to activate the Polar F11 Fitness heart monitor unit.
    • 2 Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button. There are five buttons and the "Light" button is at the top left side of the unit. Continue to hold the buttons until the display fills with digits.
    • 3 Press the "OK" button, which is located on the right side of the unit in the middle of the up and down buttons. The Polar F11 Fitness heart monitor will reset.
Instructions to reset a nordictrack cardio track watch
You may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions:
    • Press any button to activate the Polar F11 Fitness heart monitor unit.
  • 3helpful
    I was exercising and wearing my Polar F11 and it locked up. What do I do to get it to unlockl?
    This worked for me. From the manual, "If there are no reactions to any buttons, reset the wrist unit by pressing all the buttons simultaneously for two seconds. All other settings but time and date are saved."
    1helpful
    I changed my wife's Polar F11 HRM watch battery. When I replaced the battery the entire screen lit up, everything. I let it sit for a few minutes and the normal screen came up. Kind of like it was "booting...
    Try resetting. From the manual, "if there are no reactions to any buttons, reset the wrist unit by pressing all the buttons simultaneously for two seconds. All other settings but time and date are saved."
    Is it possible the watch block is not in correctly and the display is getting squished?
    My F11 Polar HR monitor is not working correctly
    You should have someone who is use to servicing heart rate monitors take a look at it. There are parts in the monitor that can corrode and would need to be cleaned. Also, look into replacing the battery in both units (Strap and wrist) and make sure the unit is reset properly.
    Heart rate reading low
    try this link for the manual.
    polar f11 heart rate monitor manual Google Search .
    However, you may wish to reset the unit and start over with new settings. You can resetyour Polar F11 by following a few easy steps. Press any button to activate the Polar F11 Fitness heart monitor unit. Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button.
    How to Reset a Polar F11 ' Healthfully
    https://healthfully.com/reset-polar-f11-7176556.html reset polar f11 heart rate monitor Google Search
    1helpful
    3answers
    How do I change a battery on polar monitor F6
    Open Caseback. Unclip the contact. Replace battery, clip contact back and put the caseback on.
    3answers
    Polar F11 blank display
    Sounds to me as the integrated circuit has been damaged.
    In this case you will not be able to repair it yourself as watchmakers skills needed.
    2answers
    Top Polar Exercise & Fitness Experts
    Sportsmith LLC
    Sportsmith LLC
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
