Question about RCA P46924 46" Rear Projection Television
RCA P46924 I have a conversion problem. Just happened when the TV was turned on. How can I pinpoint the problem and then fix it?
  • RCA Master
  • 8,617 Answers
If you cannot adjust the red or blue in all 4 directions in the conversion adjustment menu. Your Convergence ICs are bad and will need replacement. Let me know if you need any further instructions.
Posted on Mar 01, 2008
Where is the reset button on an rca model#p46924 46" projection screen tv?
Hello
Reset button is on its remote control itsef. You can locate it at the bottom right side. Point it towards TV, and reset the setting you want to. OK.
Apr 22, 2011 | RCA P46924 46" Rear Projection Television
Turned on my RCA P46924 today and played fine for 5 min. then picture curved and turned to 3 different colors seperated on same screen. Turned TV off and now will not turn back on. Please help?
Ur tv have convergence problems,before ur convengence ICS totally went dead.U must have tools like soldering iron,solders,solder witch,and know how to solders to fix this problems ur self.Must replaced 2 convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | RCA P46924 46" Rear Projection Television
TV doesn't have picture
it could be several things..no high voltage..bad tube...crt board problem..suggest you take to repair shop...compare prices of new tvs...repair at least 150$
Mar 22, 2009 | RCA P46924 46" Rear Projection Television
RCA P46924 46" Rear Projection Home Theatre Gone Haywire
the button cluster in the front may have a bad tack switch(button) or the buttons may have loose connections. you can take the speaker grill off and look yourself...watch for wires..unplug your tv first:) also if you use spray cleaner that may have seeped into the button cluster too...you may be able to get the cluster as a whole from a local tv repair shop and put it in yourself..save labor charges:)
Mar 21, 2009 | RCA P46924 46" Rear Projection Television
RCA P46924 46 in rear projection tv will not turn on
More than likely it has bad solder connections on the circuit board. You could try tapping lightly on power supply/deflection boards to see if it makes contact. Usually I find bad solder on those right under where the power cord plugs in, on the bottom of the board. If you have a soldering iron and solder you could save a few hundred dollars in repair costs, but use caution and make sure all power to set is disconnected. Maybe mark each plug as you disconnect them. Hope this helps. Good luck, Russmann.
Jun 02, 2008 | RCA P46924 46" Rear Projection Television
No power
Yes could be several problem, the first one in my mind is burt horzirontal transistors, Q14401 or bad hight voltage block.
Could be convergence problem that is causing the system to shout down.
Hope this helps
What About Bob
Mar 01, 2008 | RCA P46924 46" Rear Projection Television
Picture conversion
Hi,you have a bad convergence board.Try calling a tv parts house to buy one .They cost about $120.
Jul 22, 2007 | RCA P46924 46" Rear Projection Television
RCA P46924 46" Rear Projection Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
