Refrigerators Logo
Posted on Feb 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kenmore refrigerator is not cold - Refrigerators
Anonymous
Level 3:
  • Master 1,891 Answers
  • Posted on Feb 23, 2010
Anonymous
Master
Level 3:
Answers
1891
Questions
0
Helped
409042
Points
5205
The coil under neath the unit may be dirty and need cleaning . . ck that both fan inside and under neath or working . and that your door seal are clean and in good condition . **** ..
1helpful
Kenmore elite refrigerator won't get cold
You either have
1. A bad thermostat
2. Defective compressor
OR
3. A leak in the fridgeration system.
You will want to call an appliance service center for assistance.
I have a side by side kenmore coldspot model 52259100. The Refrigerator is not cold but the freeze is cold. Help!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Kenmore S/S-Cold air from freezer not blown to refrigerator
check for any ice blockage ad damper operations
Kenmore refrigerator 25364150400 fridge won't get
check your evaporator coil in freezer it is froze up ,need to check to make sure defrost timer is working. Also check drain line.
2helpful
2answers
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Kenmore Elite Stainless French Door Not getting cold
This unit may be frozen up.  Defrost completely to allow the passages to get a free flow of cold air.
1helpful
Kenmor frig not getting cold
same problem then suddenly would not shut off, kept running. found out it was the thermo couple as well as the timer.
Kenmore cold spot refrigerator freezer
wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
