Question about Directv D10 DTV Receiver
PURCHASES LISTED IN THE PROGRAM GUIDE?
The Pay-for-View of DIRECTV lists all of the purchases under the program guilde; I want to know how to delete these from my TV.
    Master:
  • 555 Answers
Go to your DirecTV account online and manage your Pay-Per-View list from there.
Posted on Feb 29, 2008
  • Matt Jurach
    Matt Jurach Feb 29, 2008
    If you need technical assistance, you can call DirecTV's home customer support center at 1-800-494-4388
  • Matt Jurach
    In some DirecTV receivers, doing a complete system reset will erase the viewing history (along with all recorded shows, channel settings, etc.)
    But on most of the newer receivers, the PPV info is actually stored on the Access Card, and so resetting the receiver will not delete this information.
    The only option in that case is to buy more PPV shows until they push the former purchases off of the bottom of the screen...
Uninstall vgrabber toolbar
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. and you might have other web search toolbars interfering
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if don't need any of them you can disable or remove them
also b> http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Then delete cookies Here is a very simple guide on how to delete cookies manually from your computer.
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted.
Feb 01, 2013 | Computers & Internet
Hi need remote codes 4 a akura tv all for one. Control
if you happen to have Directv satellite service ( or know someone who does) the codes will be listed under the program remote category in the menu function
Oct 03, 2012 | Computers & Internet
Is there a DirectTV remote control code for an Ario TV?
i have an ARIO TV 32" and I used common code 10019-10178-10030-10835 to program my direct tv remote. anything is working , but only channel is not woking ,please can they help me out , how i program channel
Nov 21, 2011 | Televison & Video
I lost my remote and need to switch the tv so I can get Directv - how can I do this without my remote
I can help you with your Toshiba TV & DirecTV remote control.
To get your TV setup so that you can view your DirecTV on it, I recommend you program your DirecTV remote to control your TV and then use the DirecTV remote to change the input of your TV to view the DirecTV programming.
You can choose between searching for the control code and
entering a code from the Toshiba TV list.
This is a list of all the Toshiba TV control codes for DIrecTV remote controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, 11971
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Code Search
DirecTV Remote Control Onscreen Setup
Apr 23, 2010 | Toshiba 24AF42 24" TV
I have a rca guide plus gemstar universal remote for 6 components and need to program a daewoo 13in tv with built in vcr
Okay, when you purchased the remote, it should have had a list of TV brands listed. What you do is find the brand of television that you, which you have listed as a Daewoo, look at the description listed on that paper. It may have a few codes. Follow the instructions for the NEW remote. It will tell you to press a certain button, watch it flash 2 times and then enter the Daewoo code. It should program after that. If you have the OLD remote, you can "learn" the buttons from it to your new one by pointing the remotes towards each other. You will have to press "VCR" and then press, FFWD, REW, PLAY, PAU, etc., pointing the remotes at each other each time you press the button on the old. Sounds confusing but you will see it is very easy.
Post back if it does not work.
Nov 01, 2009 | RCA DIRECTV Satellite Remote Control
Delete from add delete at control panel
The only way to modify the add/remove programs list is to edit the registry. If you are uncomfortable doing this, get someone to help who is, or just leave the registry alone.
It's best to back up the registry in case you make a mistake.
To back up your registry, see this article.
On to the fun part. Follow these instructions exactly. Note: this applies to Windows XP only. If you have Windows Vista, please modify the question.
  1. Click Start, and then click Run.
  2. In the Open box, type regedt32, and then click OK.
  3. In Registry Editor, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
  4. In the left pane, click the Uninstall registry key, and then click Export on the File menu.
  5. In the Export Registry File dialog box that appears, click Desktop in the Save in list, type uninstall in the File name box, and then click Save.
  6. Each key listed under Uninstall in the left pane of Registry Editor represents a program that is displayed in the Currently installed programs list of the Add or Remove Programs tool. To determine which program that each key represents, click the key, and then view the following values in the details pane on the right: DisplayName: The value data for the DisplayName key is the name that is listed in Add or Remove Programs.
    -and-
    UninstallString: The value data for the UninstallString key is the program that is used to uninstall the program.
  7. After you identify the registry key that represents the program that you removed but which is still displayed in the Currently installed programs list of Add or Remove Programs, right-click the key in the left pane of the Registry Editor window, and then click Delete.
    Click Yes in response to the "Are you sure you want to delete this key and all of its subkeys?" message.
  8. On the File menu, click Exit to quit Registry Editor.
  9. Click Start, click Control Panel, and then click Add or Remove Programs.
    In the Currently installed programs list, verify that the program whose registry key you deleted is no longer listed.
  10. Do one of the following:
    • If the program list is not correct in Add or Remove Programs, double-click the Uninstall.reg file that you saved to your desktop in step 5 to restore the original list of programs in the registry.
      -or-
    • If the program list is correct in Add or Remove Programs, right-click the Uninstall.reg file on your desktop, and then click Delete.
Mar 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
I have a direct tv rca universal remote guide plus
Check this old web site at wf1broward.com and ask for nelson, david or Mark... lol
Mar 28, 2008 | RCA DIRECTV Satellite Remote Control
Codes dont work for hd directv
Remote codes
http://www.remotecentral.com/index.html
Mar 16, 2008 | Big Button TV Universal Remote
If you have a D10-200, use this manual.
If you have a D10-300, use this manual.
Look in the "System Preferences" section.
Feb 29, 2008 | Directv D10 DTV Receiver
Directv D10 DTV Receiver Logo
100 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
