Question about D-Link AirPlus G DWL-G122 802.11g/b Wireless Adapter
Keeps dropping the Wireless network
Hi guys
My son is on my wireless LAN. It has worked pretty well, but this weekend he keeps getting thrown off the network. It seems to be broadcasting just fine.
We can then change something (like go from channel 6 to channel 1) and then he is on for 10-20 minutes or so again. I'm very confused!
We've tried reinstalling the drivers and manually configuring the connection instead of letting windows do it. We can get it running, but only for a short while.
  • Magraev Mar 18, 2008
    Thanks very much for the reply. I actually have a cordless phone, but have no idea how to change the frequency... I don't think that is the problem either.
    I've tried installing the wireless adapter on my own computer and I've tried bringing home another computer with built-in wireless reciever. Both work fine.
    I suspect my dear son is going to have to format his harddrive. Other than that I don't know what can be wrong with his computer? I tried starting it in "safe" mode and it still didn't run.
  • maxxies May 05, 2008
    DLINK WILL NOT CONNECT TO SECOND COMPUTER WEVE TRIED RELOADING/INSTALLING EVERYTHING AGAIN BUT STILL WONT CONNECT ALSO WHEN WE SHUT THE SECOND COMPUTER DOWN,WHEN IT REBOOTS IT KEEPS SAYING ITS JUST RECOVERED FROM A SERIOUS ERROR
  • 55 Answers
If you have 2.4 GHz phone in your house, it might interfere with your wireless network. Switch all your cordless phones to 5.8 or higher.
NetSalem
Posted on Feb 29, 2008
We havea TRENDnet Wireless AP TEW-430APB - keeps dropping wireless
It can drop signal if there are other devices working in 2.4GHz band interfering with it. Try to switch over to 5GHz band.
Aug 29, 2017 | Trendnet TEW-430APB Wireless Access Point...
I have a sbg901 motorola ca el modem/router combo. My comcast network gives me speed of 20mbps. The issue I have is that the network often gets disconnected sometimes very frequently. The second issue I...
This sounds like network issue ISP...call them they will trouble shoot for you..ping your modem ..is this wifi or lan that's dropping speed ? Take a Ethernet plug one end into modem and the other end into your computer , if it stays on it's not your modem . When you test modem make sure router is not attached, This will tell you its your router is dropping wifi..now if this does not work on the modem it's the modem or ISP...if you have combo modem with router still plug Ethernet to test connection...I can go more into detail just don't want to confuse you...I hope this help...
Dec 16, 2017 | Arris SURFboard SBG901 Wireless Cable...
No wireless on Time-Warner cable. LAN works fine
Yes, from what I understand you need a special router to go wireless with timewarner, just another way coporate America dicks the regular guy.
Dec 18, 2009 | D-Link DIR-615 Wireless Router
My laptop wont search for any wireless networks, it keeps saying that there are no connections available when i know there are
There may be a switch to turn the wireless on and off - it will usually have an antenna icon next to it.
Nov 14, 2009 | Gateway MX6920 Notebook
My wireless network gets dropped
HI! that is correct.. your device wont connect bcoz you change the wep, ssid name etc on the router.. if the security settings is change from the router and your wireless devices have the old settings it wont work and it will not connect.. you need to enter the new wep, ssid name etc to the wireless devices in order to connect to the wireless network..
Jul 10, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Intel PRO/Wireless 2100 LAN 3b mini card PCI adapter
I had this same problem this weekend. This is a 802.11 B card. It can use WEP and WPA for network security/encryption. You can find the driver here -> http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-67214
Once you download the file run it and install. Your wireless card will then work.
Note: This adapter will not support WPA2 type network encryption. It will only run at speeds up to 11Mbps on the 2.4GHz band. Make sure you have set you router to support this older format.
Jun 14, 2009 | Intel PRO/Wireless 2100 MiniPCI 802.11b
Wireless doesn't work
Hi Friend,
Kindly check the below given instructions,
To access the WIRELESS (WLAN) settings window, click on the Wireless Setup button in the SETUP directory.
WIRELESS NETWORK SETTINGS
1.Click on the Enable Wireless box to allow the router to operate in the
wireless environment.
2.The SSID identifies members of the Service Set. Accept the default
name or change it to something else. If the default SSID is changed, all
other devices on the wireless network must also use the same SSID.
3.Enable Auto Channel Scan so that the router can select the best
possible channel for your wireless network to operate on.
4.The Wireless Channel can let you select the channel of your access
point. Channel availability is different for different countries due to their
regulation.
5.Select 802.11 Mode to operate in b/g/n mode. Or select specified mode
to use.
6.Channel Width, Maximum rate for 20 MHz is 130 Mbps. Maximum rate
for 40 MHz is 270 Mbps.
7.Transmission Rate, suggest keeping the Best (automatic) selection.
8.Click on the Hide Wireless Network box to allow the router to stop broadcasting its SSID.
WIRELESS SECURITY WIZARD
1.Click on the Security My Wireless Network button to enter the
2.SECURE MY WIRELESS NETWORK window.
1.Input the SSID.
2.Select the Wireless Channel.
3.Select the Encryption type. WPA-PSK is more secure than WEP 64 bit.
4.Click on the Apply Settings button to apply the settings
WIRELESS SECURITY MODE - WEP
1.WEP (Wireless Encryption Protocol) encryption can be enabled for
security and privacy. WEP encrypts the data portion of each frame
transmitted from the wireless adapter using one of the predefined keys.
2.The router offers 64 or 128 bit encryption with four keys available.
Select WEP Key Length from the drop-down menu. (128 bit is stronger
than 64 bit)
3.Specify the encryption key from the Current Network Key drop-down
menu.
4.Enter the key into the WEP Key field 1~4. (Key length is outlined at the
bottom of the window.)
5.Select Authentication type from the drop-down menu. (Shared is
better than Open)
6.Click on the Apply Settings button to apply settings.
Check and revert back
Regards,
Ayyasam
May 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
System Crash
Hi
Intel 2200BG is known to cause this and similar errors when Wireless Application Protocol (WAP) encryption is used. The problem has been around since 2004 and new OS Drivers should fix this.
I recommend you download and install latest Windows Drivers (appropriate for your Windows Version) for Intel 2200BG Adaptor.
If this cannot be done, then setting your wireless to Wired Equivalent Privacy (WEP) encription (though less secure) will minimise these error conditions
NB: Google "w22n51.sys" for more info.
Regards
Mike
Mar 27, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
My network wireless adapter keeps dropping off
I would check with HP and see if they have a Vista driver for the wireless card. It sames to be the driver is in consistant.
Jan 03, 2008 | Computers & Internet
D-Link AirPlus G DWL-G122 802.11g/b Wireless Adapter Logo
81 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
