Windows xp had a problem when i updated my msn messager and i restarted my computer and now it won't load windows..it come up as 0x00000024 and 0x001902fe on the blue sceen..i had tried all and everything even tried from F 8 and tried to restart..
You can try booting from your WIN XP CD choose the "R" for repair using the Recovery Console option, when you get to the command prompt type CHKDSK /R (you'll need the admin password) and press enter, let it run the repair and see what happens
Posted on Feb 29, 2008
Error message stop 0x00000024
which operating system ?
If you get the Windows blue screen, you can determine which stop code you have and determine what you need to do in order to get your computer back to working correctly.
First, make sure that you have this error code - Stop 0x00000024 or NTFS_FILE_SYSTEM. This message shows that a problem occurred within Ntfs.sys, the driver file that allows the system to read and write to NTFS file system drives. One possible problem is a malfunctioning SCSI and Advanced Technology Attachment (ATA) hardware or drivers. This can also adversely affect the system's ability to read and write to disk, causing errors. If the computer is using a SCSI hard drive, check both for cabling and termination problems between the SCSI controller and the disks. You will need to periodically check the Event Viewer for error messages related to SCSI or FASTFAT in the System log. You can also use Autochk in the Application log. Try the following. First, Double-click My Computer, select the hard disk you want to check. Then, on the File menu, click Properties. Then, click the Tools tab. Next, in the Error-checking box, click Check Now.
Finally, in Check disk options, select the scan for and attempt recovery of bad sectors check box. You can also select the Automatically fix file system errors check box.
http://answers.microsoft.com/en-us/windows/forum/windows_xp-system/windows-xp-blue-screen-error-message-0x00000024/9d6475ed-dc42-4fa7-a2a2-506c42f6ee63
Feb 24, 2013 | Computers & Internet
Tip
Disable Automatic Reboot after Windows Update
Have you seen the message
"Automatic Updates
Updating your computer is almost complete. You must restart your computer for the updates to take effect.
Do you want to restart your computer now?"
Automatic Windows updates are very good for computer security. However, when these Windows updates are downloaded and installed on your computer, if the updates require a reboot of your computer, Windows keeps prompting you to reboot your computer.
Now, Windows XP Pro users can disable automatic reboot of the computer after a Windows Update. In order to do that, follow these steps
Disable Automatic Reboot after Windows Update for Windows XP Pro usersWith this setting you will be able to specify that after a scheduled Windows update, Automatic updates will wait for the computer to be restarted by any user who is logged on, instead of causing the computer to restart automatically. If this setting is not enabled or not configured, your computer will prompt you every 5 minutes to restart the computer to complete the installation.
1. Press <Windows Key> + R which will launch the Run command. Type gpedit.msc and press Enter
2. Group Policy Editor will now be launched
3. On the left hand pane, under Local Computer Policy, click on the (+) sign next to Computer Configuration
4. Click on the (+) sign next to Administrative Templates. Then click on (+) next to Windows Components and then click on Windows Update
5. Double click on No auto-restart for scheduled Automatic Updates installations. A settings window will now open. In there, select Enabled and then press OK
6. Close the Group Policy Editor
Disable Automatic Reboot after Windows Update for Windows XP Home usersThe settings are a bit different for Windows XP Home users because there is no group policy configuration for Windows XP Home.
1. Press <Windows Key> + R and type in regedit. Press Enter
2. Navigate to
HKEY_LOCAL_MACHINE SoftwarePolicies MicrosoftWindows WindowsUpdateAU
3. Change the "NoAutoRebootWithLoggedOnUsers" DWord value to 1 to Disallow auto reboot.
4. Press OK
if this tip really help u pls vote ,...........shailendra
on Oct 03, 2010 | Computers & Internet
Tip
WINDOWS LIVE COMMUNICATION PLATFORM ERROR/ LOGIN PROBLEM
if you have problem with msn messenger 2009 not working properly in win xp sp2. you can update your windows by download "WindowsXP-KB936929-SP3-x86-ENU.exe" by search in google from microsoft site. the file is of 316 MB. then your computer became win xp sp3. now install msn messenger it will work properly.
on Dec 22, 2009 | Microsoft Windows Live Messanger
Everytime i try to log onto windows msn error 8e5e0247 comes up
Try installing this update from HP and restart your PC and try to login again.
MSN Update
If this does not help, you need to uninstall the MSN Messenger and reinstall it.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 29, 2010 | Microsoft Windows Live Messanger
The problem I'm experience with my computer start when a blue sceen appears. The statement states: A problem has been dected and windows has been shut down to prevent damage to my computer. If this...
If you are running Windows XP, the boot to the XP CD, press R when prompted to access the Recovery Console, then run the command CHKDSK /R at the C:\windows\system32\ prompt
If you get indications of recovering lost allocation units, then the disk surface of the HDD is likely bad and the HDD will need to be replaced.
If running Windows Vista or Windows 7, boot to the Windows DVD and select REPAIR MY COMPUTER
Dec 23, 2010 | Dell Computers & Internet
DELL DIMENSION 2400 ERROR STOP: 0x00000024, (0x00100203,0X82F898
You seem to have an error in the boot sequence of the Operating system. If you are unable to access the safte mode of the OS, then you will have to do a hard boot (boot from disk). My suggestion is seeing that you have a Dell, many times they will give you a boot disk or charge you $10 for one to be sent to you. Boot disks are not expensive at all.
Once you recieve the boot disk, go into the BIOS and change the boot sequence that it boots from your CD/DVD drive first instead of your hard drive (C). Then restart the computer with the disk in the disk drive and it will load from the disk.
If that does not work, you will have to do a reimage. For that you will need a Windows OS CD (XP, Vista - whatever OS you use). From there you can either have your data slaved over to another drive prior to reimaging, or if you dont mind loosing the data, just push in the Windows OS CD and it will ask if you want to over write or reimage, answer yes, and it will begin to wipe your computer and place a brand new copy of the OS on there.
Jan 02, 2010 | Dell Dimension 2400 PC Desktop
Our email which is serviced by msn intrnet explorer has quit
some file in the system are corrupted probably by some mal-ware or some virus. do u have any anti-virus installed on your computer?
what i can suggest you is try accessing your e-mail from other browsers like Mozilla firefox or safari. or you can try reinstalling the internet explorer.
Mar 14, 2009 | Microsoft Windows XP Home Edition with...
Blue Screen Error Message
Looks like you've been getting two different Stop errors...
The 1st error, 0X00000024, aka Stop 0x24, is a Windows 2000 error. (XP is just an updated version of 2000) Microsoft gives an explanation here.
For the 2nd error, starting with 0x000000ED, Microsoft's solution is here, with additional help here.
Jan 02, 2009 | Dell Dimension 3000 PC Desktop
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
