Question about Refrigerators
Kenmore refigetater/freezer replaced starting capacitor with new one but the unit sometimes starts up properly but after reaching temp will not restart. you can hear it clicking to start but wont. the unit will cool down properly when it does start up but will not restart
Hello ikenfixit,
I have a problem white the Compaq R3000 (intel)2800.
I get a blue screen 4 or 5 times a day.
i have reinstall XP Sp2 Pro (a clean instaletion) but still
blue screen and resets.
I have release and replace again, memory - processor - wireless module and the problem was solved for two weaks, but now it back again, please can you tell me what the problem can be?
Sorry for the orthography errors but I am Dutchman.
Thanks already for youre answer.
Greetings Kees
Posted on Feb 29, 2008
    Scholar:
  • 163 Answers
Thermal Snapdisk probably.. Have a DVM?
  • Ken LaDere Feb 29, 2008
    VRAM is the issue.. (Video Memorey and its BGA Mounted).. Intel or Athlon based unit? Also Which video chipset...
Samsung Fridge freezer - switches on fine. reaches correct temps .. turns off .. and then dont come back on again HELP HELP HELP
Hallo
It could be the compressor winding's starting to cause it not to start up after running for a while because the drier is blocked and when the drier is blocked it will start running in a vacuum causing it to spark(burn) on the inside of the compressor or could still be in a vacuum and causes it to spark when it should start.
Regards
Jun 22, 2016 | Samsung Refrigerators
I have a Kenmore 5 cu ft freezer that won't come on. I've tested the power cord and that's not the problem. Where should I start looking?
Make sure that power is reaching the motor after going thru the thermostat.
If juice is there replace the starting capacitor. If the motor gets hot but still does not run the rotor might be frozen - check with ammeter for abnormal current draw.
If compressor is frozen all you can do is replace unit.
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
Kenmore trio freezer and fridge not cooling. we used to have problems where the fridge would be perfect but the freezer was always too cold, sometimes causing the freezer door to freeze shut. but we had a...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 19, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Our refrigerator started having problems by freezing stuff like milk, now the milk is curdling in a day or two. We have the temp set at 33 and it is still not working properly.
heatman101
Sep 13, 2011 | Kenmore Top Freezer Refrigerator
My Kenmore side by side (about 6 yrs old) has a problem with the refrigerator side. The temp inside the fridge has dropped to a steady 55-60 degrees, even with setting on high. The freezer is working...
heatman101
Sep 01, 2011 | Kenmore Side by Side Refrigerator
Compressor goes off on overload. Replaced the overload relay,the ref. came down to temp. and would not restart. Installed a new start kit with overload and capacitor. Same results,came down in temp.but...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Mar 23, 2011 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Chest Freezer Model number 1987191852 has started to defrost own its own. Compressor starts and shuts down after appx 2 seconds. Has this unit reached the end? is it cost effective to repair?
Good day,
That short cycle you hear, is the compressor trying to start, and can't.
It is possible one of the start components has failed. Under a cover on the side of the compressor are either 3 or 2 components.
The start relay, the protective overload and on some models a start/run capacitor. These components can be removed by pulling them off of the pins of the compressor.
Most appliance parts houses will be glad to test them for you. Replace any that test bad.
If all test O.K. then it is an internal problem with the compressor itself, which would take the services of a trained tech and pretty pricey.
Apr 11, 2010 | Kenmore Freezers
Freezer temp
No, these fluctuations are a sign of a unstable control unit. test the control unit for its operational value and , replace the thermostats as well.
May 22, 2009 | Kenmore 64722 Top Freezer Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
