Question about Sharp AL-1641CS Laser Digital Copier
Sharp -AL1644 flashing L6 error
Can anyone please tell me what error L6 mean for this printer. Also a part number for any necessary part.
  • chaffyhuns Feb 29, 2008
    Thank you, that is all I need.
    Problem Solver:
  • 5 Answers
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Posted on Mar 18, 2008
  • 81 Answers
This code indicates a laser error. You will spend between $250 and $300 for the part. Installation is not easy and should be handled by a professional.
Posted on Feb 29, 2008
SC L6-10 ON 5631
i have problem in my photo copier sharp ar203e the problem is op what mean?
Mar 22, 2013 | Sharp AR-M450N Copier
I have an Error on my Sharp AR-M350n+ copier that says "L6-10" Can you please tell me that that error code means? Thanks
L6 10 Polygon motor trouble
it is a very common problem on sharp copiers
that means the laser unit is defective, tou have to change it , allso is very expensive..
regards,
Adi
Nov 03, 2010 | Sharp AR-M350N Copier
I have a Sharp AR-M280N copier and it has an error code of L6-10 on it can you tell me what that means?
An L6-10 code means that the polygonal motor isn't rotating at 25,000 r.p.m. This motor is located inside the laser unit of the machine. You can try this procedure to try and reset the machine. Press the following buttons in this order: #,interupt,C,interupt,1,4.The operation panel may ask if you want to do this, choose "yes or 1". Then press the "copy" button as if you were making a copy. This will reboot the copier. The polygonal motor will need replacing soon regardless.
Oct 15, 2010 | Sharp AR-275 Copier
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
How to download ringtones to Motorola L6
I wish to download ringtones to my Motorola L6. Can anyone tell me how? Thanks.
Nov 29, 2008 | Motorola Mobility L6 Cellular Phone
Error Code
L6 means : Rotary cassette position sense failure
The Cassette position sensor is defective, or there is a failure in the RC motor .
Call Sharp support using the phone number listed on the owner manual.
Nov 16, 2008 | Sharp AR-M205 Copier
FLASHING ERROR 6 L
L6:The Main PWB sensed a Polygon motor lock signal error. 5-L6 only: Check the connector CN23 on the Main PWB and the wires and connectors on the Laser Module. If connector and wires are not damaged, replace laser module. What that normally means is the laser mirror motor has failed. That normal price for that item is normally over $300. Here is a parts dealer to contact to see if they have it in stock. https://www.partsdrop.com/store/
May 15, 2008 | Xerox WorkCentre XD120F Laser Printer
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Xerox XD100
I have a XD100 Work Center with a L6 error code indication. After press "C" Clear (orange color button), followed by "Auto" (the most left small button) - exposure mode key; and "C" followed by "Auto" again, the copier starts to print and solved problem.
Nov 02, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Sharp AL-1641CS Laser Digital Copier Logo
2,382 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
