Question about T-Mobile Wing™ Smartphone
Phone allways searching, cant make/get calls
Phone portion is consently searching, will not contect to data,please advise
  • Advance Tech Mar 04, 2008
    it requires an activision code to unlock network
    How to get a solution without T mobile company or dealers. Is there any way????
  • BRAHMS18 Oct 03, 2008
    all my phone does is search,i cant make or receive calls, alredy tried to reset it it still does the same thing, i even updated it and still the same problem
    Scholar:
  • 62 Answers
I dont see how it would require any activation code... It sounds like some settings are messed up. Back everything up and do a full reset.
Use a program like PIM Backup (http://www.pocketpcfreewares.com/en/index.php?soft=1806)
Save the backup to your memory card, or back it up and copy it to your computer, the do the Factory Reset. You can then reinstall PIM Backup after the reset and use it to restore most of the stuff on your phone (contacts, call logs, text messages, etc.)
Factory Reset instructions:
•Hold down both soft keys (both above the send and end key's) and use the stylus to push the reset button in between the volume key and micro sd slot. Then the screen will turn on and tell you something to the extent of press "Send" to perform a factory reset. Hit send, and your good to go.
Posted on May 18, 2008
Need to find out password to samsung admire
Products allways comes with a 12345 password if you did not change it, try it, but if you did change it, think of what kind of password you allways use on your everyday life, like dates, birthdays,phone numbers, license plates....
Dec 22, 2013 | Samsung Admire SCH
Hi.. i have my samsung star 3g(gt-s5603) and i allways put an passward in it for safety bt nw when ever i insert the code it didnt opens, guys please help me out from this problem
hi
if phone can be access menu with or without sim
just type the code *2767*3855# and all data from phone will clear out and password reset to default
if cant access phone , then you need to go repair shop
Oct 17, 2010 | Samsung Star GT-S5233 Cell Phone
Fridge does not cool down
dear sir,
if your freezer,s compressor is running the i think its low gas problem please contect to your service technician for refilling refrigarant .
hope answer the question
thank you
please vote!
Jul 01, 2010 | Engel MT45FU1 Chest Freezer
Nokia team please help me .i have (20pcs) 5130 mobile set in end user's5130 in problem contect service .when mobile switch on after nokia shakehand disply showing contect service.when i use in verious...
This problem has no specific solution, but the only and the final solution is "Flashing". For nokia, Ufs and Jaf boxes are the best flashing software. If these two can't flash your handsets, then there must be internal problem like cpu or power supply ic. If this is the case, repairing or getting repaired would be tough.
If all your 20 sets aren't working and displaying the same problem and asking for the same key, you better take another look at the flashing software. There must be error and something must be wrong with it. I wonder how 20 pcs got the same problem, you must look into the matter very carefully, otherwise, you'd damage more sets. You also need to replace your data cable for the particular model.
Good luck.
Thanks for using FixYa.
Jun 28, 2010 | Nokia 5130 XpressMusic Red Unlocked Import...
Nokia display problems
these is because of your display is dead u need to change the display or belt of display for that u can contect near customer care of nokia
Oct 02, 2009 | Nokia N72 Cellular Phone
I am delete the search icon please advise me reinstallation the search icon
To find the icon is hard. Back up your data using Nokia PC Suite and reinstall (or update ) your firmware.
Apr 07, 2009 | Nokia N73 Cellular Phone
Contact Names
in nokia 6600 when you open contects from your phone it only shows your phone contects so right clik on option than there is option to sim contect open it and copy all to your phone than every time you can find your contect easyly
Dec 06, 2008 | Nokia 6600
Nokia 6233 Phonebook is not showing the contect numbers
Turn off all your password requests,etc in the security settings of your phone and try to search your phonebook again. That could be the reason of protection.
Pls rate this solution according to the use obtained.
Sep 20, 2008 | Nokia 6233 Cellular Phone
Consent ui for administrative applications has stopped working
Consent.exe is part of Windows Vista - it's the User Access Control (UAC) executable.
There is a known malware version of this executable. Do a search on your hard drive (within Windows Vista, obviously) for all consent.exe files - make sure you include hidden and system files in the search criteria.
Once the search has completed, right-click on each file and check the file properties.
There is a MalWare version of Consent.exe
Right Click ALL of the ones you find and look for
Microsoft details in Properties
  • File Names Used: 3
  • Paths Used: 8
  • Common File Name: CONSENT.EXE
  • Common Path: ?:\windows.old\windows\winsxs\x86_microsoft-windows-lua_31bf3856ad364e35_6.0.5728.16387_none_ef1113b929fe5371\
  • Vendor Information: Microsoft Corporation
  • Product Information: Consent UI for administrative applications
  • Version Information: 6.0.5728.16387
  • CONSENT.EXE may use 3 or more path and file names, these are the most common:
  • 1 :%windir%\winsxs\backup\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • 2 :?:\windows.old\windows\winsxs\backup\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • 3 :?:\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • If you find a consent.exe anywhere else in the search results, I'd delete that file. Run a thorough anti-virus scan of the harddrive. I'd also download spybot and run it as well as downloading Ad-Aware from Lavasoft and using it to scan as well.
    Spybot and Ad-Aware can find different spyware/malware, which is why I recommend running both products.
    Once you've done all that, reboot the system. That should fix the problem.
    May 08, 2008 | Computers & Internet
    T-Mobile Wing™ Smartphone Logo
    49 people viewed this question
    Top T-Mobile Computers & Internet Experts
    ismael castillo
    Marvin
    Marvin
    Edward Talavera
    Edward Talavera
    Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
