Question about D-Link AirPlus DI-524 Wireless Router
Coverage and speed have reduced
Hi I have a d-Link DI-524 wireless router connected to my modem.Both speed and signal strength have disimproved recently for no apparent reason. I have changed the SSID and channel but this has not helped. Does anybody have a solution to this problem?
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Have you moved the location in your house of the router or wireless devices? Who is your ISP?
    Novelist:
  • 188 Answers
You can find the complete solution on the web link given below.
Please click on the web link given below and check for the exact issue and solution to get the issue fixed.
http://support.dlink.com/supportfaq/
I hope this will help you further with the router information and maintainence.
Have a great day!
Posted on Mar 21, 2008
D-LINK DI-524 coverage Issue
You can reboot ALL the devices . Unplug the Modem, remove battery, Unplug the D Link. Install battery in Modem, plug into AC, allow the device to selftest, plug in D Link allow it to self test. Reboot computer. Have you secured the wireless? Changed Channels for better signal? Take a look at this: http://www.microsoft.com/athome/setup/wirelesstips.aspx#fbid=nZTFiYrDLMg
Dec 05, 2012 | Computers & Internet
Connecting to internet
you need to configure wireless on router panel using the browser.
Apr 16, 2008 | D-Link AirPlus DI-524 Wireless Router
I have the d-link 524 that i use to connect my xp laptop via wireless connection and my vista desktop through a hard connection. What I found is that my wireless connection continually goes down and will...
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 13, 2009 | D-Link AirPlus DI-524 Wireless Router
I Have a D-link DI-524 wireless router and verizon Broadband modem w/USB conection the G router only has ethernet connections .How can I make this Combo work?
If your Broadband modem is only with w/USB connection you have to change modem/router, you won't connect it with usb to di-524.
Jul 05, 2009 | D-Link AirPlus DI-524 Wireless Router
Can't get my di-524 router to work
no a straight cable...you are going to need to clone your MAC address on your router so that your ISP can see it.. email me at techray1@live.com
Jun 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Oct 31, 2008 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
D-link 524 router not working
Double check that you are connected to your router and not a neighbors router.
Mar 29, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
57 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
