Question about Whirlpool Duet GHW9150P Front Load Washer
Whirpool Front Loading HE washer is leaking! Hellllp!
My washer is leaking but it doesn't look like its coming from the back hoses. It's coming fromt the bottom? Can you help?
  • Allison Collier Mar 02, 2008
    Well, the soap drawer is clear. Got any more sugestions?
  • 75 Answers
Hi there i would check the softner part of your soap drawer first for blockages, you can let me know
Posted on Feb 29, 2008
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Mu Ultimate Care ii washer is leaking from somehwere underneath when starting to fill after loading. It doesnt leak when draining, what is the possible cause?
long445 -
Your issue may be a problem similar to one I have with a 5-year old Whirlpool Extra care LSQ9650PG2. After some wailing, gnashing of teeth, and toweling up a bit of water, I discovered that the washer's plastic water pump casing has developed a small crack. If this is your problem, the leak is most apparent when filling, then when sitting with water in it, then not so much (if at all) when draining. Also check hoses, and connection of hoses, as somehow they may have split, or come lose. (Mine were fine.) Whirpool.com shows that most of its top-loading direct-drive washers use the same pump - 3363394. That website sells them for forty-something dollars, if you use 3363394 as a search selector you will get other websites that sell it for much less. Other items to check are the spring clamps (two of them) that help hold the pump tight. If non-functional due to rust, bent, missing, etc. replace them (about $5 each). You will have to place the washer on its back (I placed a 6x6 piece under it), remove the spring clips, disconnect the two hoses, and be prepared to sop up more water. Highly recommended to plug any electric lights, fans, etc. only into GFI-protected outlets. Or use towels and a good flashlight. If I remember I will comment on how new pump (ordered) fits and if this plugs my leak. Good luck. mnwilli@hotmail.com
Nov 24, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore HE2T Front Loading Washer Leaks From Door
there is a dispenser hose that goes in the tub.alot of times a sock or something gets inside that hose.that would cause your trouble.take the boot off the front and look up and left to see that hose.it comes out of the tub pretty easy.
Feb 03, 2010 | Washing Machines
Whirpool Ultimate Care II washer - drips
Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
If that does not solve the leak through problem,the water inlet valve will have to be replaced.
Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
http://appliancejunk.com/forums/index.php?topic=5191.0
Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Top loading Roper Washer id leakinf water
ok tom ...ready,,,look in the back of the console you will see at each corner a recess with a phillipshead screw,,,make them come up but dont remove them,,when the console comes lose from cabnit,,flip it back,,flip it back only and let it hang backwards..now theres a connect for the lid switch 2 gray wires connected to a brown and redess,,,ok now disconnect,,next in each corner is a brass clip 1 on each side take a screwdriver and pry them up softly...now pull the hold cabinet towards you,,but leave machine..keep me posted onthejob
Jan 27, 2009 | Roper Washing Machines
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LXR94 leaks in front left
Taking the back off any washer rarely helps. Most are accessable from the bottom (you have to flip the machine on its back PLEASE BE CAREFUL, check the pump hoses (normally attached by clips to the motor assembly). As far as calling the dealer, you have to decide if its worth your time and effort.
Jul 08, 2007 | Whirlpool LXR9445JT Top Load Washer
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
