As my dishwasher has aged (4 years ish) the dishes are getting less and less clean. Glasses frequently have white film left in bottom. Mugs have coffee stains in bottom. I have to make sure everything is rinsed before I run the machine and even then its not so great.
I did spend about 20 min picking crud out of the bottom the other day and it got marginally better - thoughts?
I just had my Maytag dishwasher serviced. It was getting less and less efficient over time. The items on the top rack weren't even getting clean. The repairman showed me the problem: the water was not spraying very well at all.
There's a round water filter at the bottom, underneath the spray arm. It's a hard plastic mesh ring, maybe eight inches across and four inches high. This ring was completely covered in garbage. Gunk, pieces of cellophane, you name it. No way water could get through it. I was amazed to see how clogged it was.
He took out the ring, scrubbed in clean, and put it back. The water now sprays like there's no tomorrow. Practically like new.
The problem is the mesh ring getting clogged. Clean this out should fix problem. Also running hot cycles is good maintenance. Hot cycle is turning on hot settings and run 1/4 to 1/2 cup of vinegar in the machine while empty it will clean all the soap sludge build up and some food it dissolves residues and gets rid of smells in the machine. Run this for sure every six months. Do this also in your washing machines for clothes as well. Should run great for years to come. Hope this helps
Make sure you fill the the jet dry completely.add then raise the door up and down 3 times then refill this will let the air come out then refill somemore. also turn on water at faucet until it gets hot then start machine.let me know if it works.this is a technical tip that will save you a service call. let me know if this helps you.
