Question about Elna 2007 Mechanical Sewing Machine
Elna Contessa 410 Sewing Machine
My sewing machine is not in the product list. My product = Elna Contessa 410 Sewing Machine.
Lower tension problems. Don't pick up lower thread.
Can u please help me?
SOURCE: ELNA CONTESSA 410
I have a Elna Contessa 710 Manual. If you think it will help I may be able to scan a copy and email it to your own email address. Plz supply email address if interested or still unable to thread machine.
Posted on Dec 10, 2008
  • 6 Answers
SOURCE: Manual for Elna Contessa 310
www.janomestuff.com
Posted on Sep 18, 2009
SOURCE: cannot remember how to thread bobbin elna
i solved the problem after i had a closer look at the top of machine
Posted on Feb 21, 2010
  • 1116 Answers
SOURCE: I get loops on top and/or bottom of fabric during
Top tension back to 4 and leave the bobbin tension as is.
Make sure you have a new needle for the type of fabric being sewn installed with the flat side to the back of the machine. A bent needle can sometimes go unnoticed.
Always thread the machine with the presser foot up and this will give proper tension to the stitch.
Check the manual to be sure you are threading correctly (always with the presser foot up) and that the bobbin thread is feeding in the correct direction from the bobbin spool and through the guides.
Take hold of the thread at the needle as you lower and raise the needle to pull up the bobbin thread. Take both thread ends under the presser foot and to the back of the machine.
Posted on Mar 11, 2010
  • 36 Answers
SOURCE: lower thread tension very loose
is the bobbin threaded correctly? the screw on the bobbin case is the point to adjust its tension.
Posted on Jun 02, 2010
Please where can i get a free manuale for a elna contessa 310-18
Hello Peet
The Elna Contessa 310 is very similar to the 410. The manual may downloaded at this link
http://www.manualsonline.com/support/other/sewing-machine/elna-contessa-410-manual-5516071
Please let me know how useful this is for you.
Happy Stitching
Mar 05, 2017 | Elna Sewing Machines
What is the rght tension for The Elna Contessa 410 sewing machine?
Every machine is different, so a "right" tension will vary. The factory standard tension setting is the midway point between high & low number...BUT that needs to be tweaked per your machine.
Skipped stitches? Be sure to use a brand new needle and a needle that is compatible with the thread and fabric you are sewing. (Replacing an old needle is the most common and least expensive fix for a lot of machine problems.)
Optimal tension is when the upper and bobbin threads meet in the middle of the fabric.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Feb 24, 2017 | Elna Sewing Machines
How do i adjust the tension on elna 2003?
Not quite sure what you are asking. The upper tension is governed by the tension disk. Higher number is tighter, lower number is looser. Usually, the mid-range is a good place to start. Tension is correct when upper and bobbin threads meet in the middle of the fabric.
NOTE--ALWAYS RAISE the presser foot when threading so the thread will seat in the tension disk!
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Just FYI:
Why my Elna sewing machine is bad Or dont buy an Elna 2007
Dec 08, 2016 | Elna Sewing Machines
Standard tension setting
I can't see your model listed, only Elna Sewing machine, which may be one of the newer ones or could also be an older Swiss made. machine. So, can't tell if you've got a top loading bobbin where the bobbin case is integrated into the machine. Or some Elnas such as the Contessa and Primula were a front loading bobbin in a case, these are a bit different in setting the lower tension.
But generally, you shouln't need to mess with the lower tension, and top tension should be in the range of 5, sometimes 4-6 depending on what you are sewing. If you are having top thread issues its more likely to be a gunked up tension device or something missed in the threading path causing the issue. If you can add in your actual model I may be able to assist more specifically.
Aug 26, 2013 | Elna Sewing Machines
Cannot remember how to thread bobbin elna
Feb 14, 2010 | Elna Sewing Machines
Elna sewing machine, the timing is out.
Hi, Purchased an elna contessa 130. could anyone advise threading procedures , as we do not have a manual with it.......problem with top tension.
Many thanks
Maureen
maureen.reinberger@gmail.com
Apr 25, 2008 | Elna 2007 Mechanical Sewing Machine
ELNA CONTESSA 410
Mar 14, 2008 | Elna 2007 Mechanical Sewing Machine
Elna threading and reverse instructions
Hi
I have a Primula 310
The reverse is located in the middle of the stitch length dial, you press in the button whilst you reverse.
When threading up any sewing machine make sure the foot is 'up' as this opens the tension disks and the thread goes between. when you lower the foot the discs close around the thread and add the tension.
Hope this helps
Oct 31, 2007 | Sewing Machines
Elna 2007 Mechanical Sewing Machine Logo
533 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
