Question about Car Audio & Video
Car rado my ford focus radio display ahs started flashing. i dont no how to stopit.. any ideas would be very welcome many thanks...bill
Hi to me it sounds like u have a loose power connection maybe even inside the radio. i would pull it out and just check that all the wires are firmly plugged in and none have been severed. if that doesnt fix it try opening it up and see if there is any corrosion on any of the main power terminals, if this is the case a bit of very light sandpaper will suffice, but make sure its light and be carefull of the other components.   Hope that works!!
Posted on Feb 29, 2008
Ford focus radio clock not working
It would not be possible that a detail cleaning would cause that to happen. When you have no display on the screen it is usually the LCD display that has failed. Unfortunately that means a new radio.
Oct 23, 2017 | Cars & Trucks
My radio is flashing alarm and volume is fluctuating, difficulty starting
what was the problem you had starting the car? did it crank or was the car died? do you have to jump start it
Jan 01, 2013 | Audi A6 Cars & Trucks
Anyone have ford focus radio code for radio serial number m247793 thanks
go on the net type in free radio codes, select a site, in questions type in your make and serial number of radio someone will give you it, it took me 10 mins to get mine
Feb 04, 2011 | 2003 Ford Focus
Wot do i do after entering my code on a 5000 rds
Radio should start straight away.
If it is the same as the 3000 series , the numbers are entered as numbers of times you push sequential keys. ie: code 1579 , push number 1 once, push number 2 five times, push number 3 seven times and push number 4 nine times.
If the display is flashing " ERR " you will need to leave the ignition on until it stops flashing and the display reads " CODE" . ( it can take up to an hour)
Hope this helps.
Apr 08, 2010 | 2000 Ford Focus
W reg ford focus 4000rds rado serial no mi500041 can you find code and how to enter it
Go to instant radio
Code will cost £5,and will show how to enter
Mar 27, 2010 | 2000 Ford Focus
05 ford focus ghia/security code/touch screen
hi, if your radio code for example is 8156 you push the
no1 button 8 times then
no2 button 1 times then
no3 button 5 times then
no4 button 6 times then hold down the number 6 button for about 5 seconds and the radio code will store automatacly and start up. hope this helps you regards
Feb 09, 2010 | 2005 Ford Focus
Ford puma 1.7 wont start!
Have you removed and cleaned battery cables/terminals? I've had, out of the blue, suddenly cables just too "dirty" to make connection...
Feb 15, 2009 | 2000 Ford Focus
It wont start
lets start with simple stuff have you checked the water in the battery?
is the battery more than two years old ?
is the battery still holding charge such as overnight ?
with the information you have supplied in your question then are the first three things i would consider after these the next thing would be is there a boot / bonnet light that might be on even though they are closed or radio left on overnight after these options the next on the hit list is the alternator charging the battery properly an auto electrician rarely charges for a battery test pop in to one before the car lets you down completely hope this is some help welcome to ask more glenn............
Nov 23, 2008 | 2003 Ford Focus
Ford focus radio display is out
The display of the radio has micro contactes around the edges of the display. The cleaning agent used to clean the dash area could have been damaged. Best reccomandation is to have the unit replaced or taken to a repair shop and have the face plate repaired.
May 29, 2008 | 2003 Ford Focus
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
