Question about Dirt Devil Reaction Twin Cyclone Upright Vacuum
Vacuum shuts down after a short time and needs to cool off before being restarted.
It shuts down like it's overheating, but it's less than 60 days old and the canister is emptied often. I saw in the user guide that it could be the thermal detector, but there is no diagram of where this is or how to fix it. I lost the paperwork for it so they won't do a return or repair.
  • Anonymous Mar 08, 2009
    unsure if this is the same problem or not with mine . Im sure that it is, and I am not the original owner of this vacuum so I don't have any of the paperwork to figure out how to troubleshoot these issues. I need to find the repair manual and or the replacement filters for this vacuum.
  • mrsjray2000 Apr 08, 2009
    I have cleaned the roller and cleaned the filter really well that didn't help, even bought a brand new filter. Didn't matter, Im going to try to replace the belt, and see if that makes a difference but it seems every time we use it the time between we turn it on and it overheats is getting shorter and shorter I was really happy with this vacuum for the first few months now its a nightmare!!! I've had a kenmore, a hoover, now a dirt devil, they are all so expensive I can't keep replacing them and I don't know what brand to even trust.
Trash it!
Posted on Aug 21, 2008
    President:
  • 1,673 Answers
Could be the protector, it usually is located by the motor. But I am sure that this has a 1 year warranty on it, so if it is less then that, take it in for warranty service. But it also could be that you have a clogged filter, hose is clogged, or the dirt inlet by the brush roll is clogged. A clog will cause the motor to overheat and shut down until it is cleared.
Posted on Feb 29, 2008
Was cleaning the floor and I shut it off to empty the canister and it wont restart
Not knowing your model of vacuum I'm guessing it could be your cord or switch is bad. If the vacuum overheated it should come on after it cools down but that is a good sign it's time to change the filters
Apr 22, 2016 | Vacuums
My shark proffesional nv502 vacuum wont power on. My daughter sucked up a sock and it shut down to avoid overheating the motor I guess. Well--3 days later andit still wont turn back on. Is there a reset...
it should start after awhile is it the whole machine or just the brush bar. oh there is no reset from what i read.over heat motor it shuts down till it cools.
Feb 08, 2015 | Shark Rotator Professional Lift-Away...
Vacuum runs for 5 minutes ,then shuts down. Will restart after 15 minutes, then does same thing.
sounds like a built in feature. It is overheating, bad wire or circuit possible
Jan 01, 2015 | Vacuums
Why does the power shut off on a dirt devil vision vacuum?
It is probably the thermal sensor which shuts the vacuum off it gets hot. It will come back on when it cools down. Replace all the filters as they are probably. Restricting the airflow
Jul 30, 2014 | Dirt Devil Vacuums
Hoover uh70035b
If it shuts off after being used for a whirl and won't come back on for a while it is probably overheating. The heat sensor shuts the machine off and won't let it turn back on until it cools down. If this is the issue it could be the filters are clogged and not allowing enough airflow to keep the motor cool. Most bag less vacuum filters should be replaced frequently even if they are cleaned regularly.
Oct 30, 2013 | Vacuums
It was working fine and them just stopped it is not that old and was not making noises HELP!!
Vacuum cleaners have electric motors in them that require proper airflow to pass over them to keep them cool. Many vacuum cleaners have a thermal (heat) sensitive shut off mechanism built in. This mechanism should prevent the burn out of the motor. If you run a vacuum too long with a clogged hose or clogged filters (especially bagless vacuums) or clogged bags, that is essentially choking the vacuum for air and not allowing it to breath properly. This will cause it to overheat and shut down. Most of the big box store purchased vacuums have very thin wires in the motor windings and can only do this a few times before the motor completely fails. If your vacuum has been shutting down, then cooling off and restarting after about 30 to 45 minutes, then shutting down after only a few minutes of use, your machine is probably clogged up or the filters are compacted.
Jul 05, 2011 | Vacuums
Vacuum shots down after a short time, restarts but runs only a short time
yes that unit has 2 sensors 1 on the motor and 1 on the relay board 1 of them is bad which is making the vacuum shut its like a heat sensors its malfuctioning it shuts the unit down
Feb 17, 2011 | Broan-NuTone VX550 Bagged Central System...
It runs for a couple of minutes shuts off then restarts 30 seconds later runs a couple of minutes and does this over and over
Most vacuum motors are protected from overheating by a thermal switch that resets after cooling down. Check for blockage in the hose,
power head or a full bag that would block cooling air from cooling the motor.
Tom
Oct 22, 2009 | Tristar Vacuums
Hoover wind tunnel
Did you check down by the brush roll for a clog in the dirt inlet. And is the brush roll turning freely, if it is being lugged down, it can cause the motor to overheat and the thermo protector will caught it off, until the motor cools down. But if both are ok, then maybe the motor protector needs to replaced, it is prematurely tripping.
Jun 19, 2008 | Vacuums
Electrolux Canister - Stops working after 1-2 minutes.
Electrolux Canister - Stops working after 1-2...
Our vac works for a short time, then shuts off and makes clicking noise as if trying to restart again. Works after cooling for a while but for another very short time. Your suggestion on fix would be greatly appreciated.
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure
I would advise that it could be a thermal switch or a regular switch that the thermal switch is over heating and needs replacement – there are small hoses in the door section that could have been pinched or kinked and it stopping the air flow from the vacuum – also check for a clogged or plugged vacuum hose, a full vacuum bag or a dirty vacuum filter. Check the thermal switch or reg switch or the hoses in the door. Or feel free to contact your local vacuum dealer in your area or in the yellow pages, or call the factory @ the phone number listed below:
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Apr 21, 2008 | Electrolux Guardian Bagged Canister Vacuum
Dirt Devil Reaction Twin Cyclone Upright Vacuum Logo
2,109 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
