Question about Dishwashers
FRIGIDAIRE DISHWASHER HI! MY NAME IS MARK AND I AM HAVING PROBLEMS WITH MY FRIGIDAIRE MODEL # FDB710LCB0/SERIAL # TH51153536 DISHWAHER. THE PROBLEM: IT DOES NOT COME ON AT ALL LIKE THERE IS NO POWER TO IT. I HAVE CHECKED THE BREAKER AND THE ELECTRICAL CONNECTION AND THERE ARE NO PROBLEMS AT THOSE POINTS. ALTHOUGH FOR A BRIEF MOMENT LAST NIGHT IT DID COME ON AND THERE WAS A "HUMMING NOISE AT THE DRAIN PUMP LOCATION (IT SOUNDED REALLY BAD) THEN IT SHUT DOWN AGAIN AND NOW IT WON,T COME ON AT ALL. ANY IDEA'S ON WHERE TO START AND WHAT PARTS I WILL NEED TO REPALCE? THANKS, MARK DOTSON
    President:
  • 2,651 Answers
Check your door switches behind console, next i would ck the circuit board for power in/out. there a tech sheet behind front panel for further diag test points
Posted on Feb 29, 2008
Is there a reset button on frigidaire dishwasher model fdb710lcb0
Mate im in Australia and don't know if the Frigidaite is the same as the Electrolux/Westinghouse but you can try this I posted a day ago:
On the Westinghouse and Electrolux dishwashers to reset a program that it defaults too you start the program and once initialised then press and hold the program button for about 3-5 secs. The panel will beep and all the lights will come on and not flash. From there on using the program button you select the wash cycle you want
May 28, 2016 | Frigidaire Dishwashers
Dishwaher does not drain cmpletely ?
Hello friend, thanks for your post!
I see you are having difficulty with your Frigidaire dishwasher not draining. Check the filter at the bottom of the dishwasher because if that gets clogged then it will not allow your dishwasher to drain properly. Additionally, check to assure that the sump pump is hooked up correctly to allow proper siphoning of your dishwasher. If that is correct it could be a potential problem with your control panel or drain pump and I would recommend consulting with a professional technician for proper diagnosis and repair. I hope this helps to some degree. -Matt
Sep 25, 2014 | Frigidaire Dishwashers
What does 2e mean on my Frigidaire dishwaher
Hello friend, thank you for your post!
I see you are having trouble with your Frigidaire dishwasher and you are receiving error code "2E". However, it appears "2E" is an invalid error code. May I have you model number please? Typically you can locate your serial tag on the inside wall on the left hand side. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 21, 2014 | Frigidaire Dishwashers
Hi, I have GE Dishwaher model GLD4406R00WW serial GT777135B. It starts and runs 50 seconds, stops and won' t pump the tub out. Any thoughts would be appreciated. Dishwasher is just out of warranty as...
Hello, grojon
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
Sep 14, 2011 | Maytag Dishwasher
Dishwaher water does not get hot enough
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
iueyj
May 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Water won't stop running into dishwaher
go to sears .com,put in your model number,click on parts and it will show you where it is-mike
Jan 03, 2009 | Dishwashers
Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Where is the drain screen at in my My frigidaire dishwasher
generic reply normly in the center and looks like a plastic grating, but is your drain hose kinked?
Oct 25, 2008 | Frigidaire Dishwashers
New dishwasher
Having same problem + won't dry. Looks like this is a crap dishwaher.
Nov 06, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire dishwasher bottom door gasket replacement
thank you so much for this information it was a god send
Oct 07, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
235 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
