Question about Mitsubishi WS-48613 48" Rear Projection Television
Cool temps cause my t.v. to not turn on
When temps inside my house drop to around 65.f my t.v.wont turn on. The led on the front shows a steady flashing pattern. I can take my hairdryer and concentrate air on the left side(looking from the back) on the metal encased board(mounts vertical and has a led on it inside) for about 2 minutes the led on the board will start to flash then go out.,then the led on the front will go out. i then have to push the reset button,then the t.v will come on. (cold solder joint?),(normally you can hear a relay close when you push the power button,but when this occurs,nothing This t.v is 4 yrs old used daily,problem occured virtually overnight
  • Jumpmaster Mar 28, 2008
    my uptmost thanx, this fixed it !!!! caps of that value were hard to find locally, but a quick trip on the internet solved everything. thanx again.
    Sergeant:
  • 395 Answers
There are six capacitors on the DM board 1000uF 16 v that go bad, repace them with 680uF 16 v. 105C. the capacitors are clustered together. on the DM board the DM board is the board that is enclosed in the metal box. the repair is not an easy one so have a tech help you. this is a known problem.
Posted on Feb 29, 2008
My Dometic digital thermostat wont go up past 32 degrees. What could be wrong?
Same problem...then discovered my thermostat was set to Celsius instead of Ferinheight... pressed toe temp up and temp down buttons to change..fixed...
Sep 16, 2014 | Dometic 3313192.000 White Single Zone LCD...
Thermostat location hemi
Find the large rad. hose at the top of the rad. follow that to where it connects to the block . there is your thermostat.
Apr 10, 2017 | 2008 Chrysler Aspen
I HAVE A 2003 TIBURON WITH A NEW RADIATOR. THE CAR HAS A TENDENCY TO INCREASE IN TEMP IF ON A CONSTANT SPEED OF 140KM. IF THE SPEED IS DROPPED TO 100KM THEN THE TEMP DROPS TO THE NORMAL OPERATING TEMP...
My guess is trapped air in the cooling system. If the cooling system was just filled with antifreeze without bleeding the air, it could cause sporadic overheating. It could also be the cooling fan not coming on at high speeds. Next time the temperature rises, turn on the defroster for th front windshield. That should cause the air conditioner to come on, which in turn will turn on the cooling fan. If the temperature drops, I would suspect the cooling fan sensor is faulty.
Jan 14, 2011 | 2003 Hyundai Tiburon
Wont get cool, can you refill?
Does AC turn on at all? if yes, remove front cover, do coils get cool at all? if no, thermostat may be bad telling unti that the desired temp reached is satified.. or.. you have the desired temp too low, if you have it set for 75 degrees, and it is 72 in your house, the fan will run and no cool air will be present.
Jul 07, 2010 | Kenmore 75085 Air Conditioner
Honeywell 5-2 Programmable Thermostat wont turn on
I'm assuming the screen is not blank, and that you can select heat/cool and nothing happens. If it's battery operated then there probably is an issue beyond the t-stat. Technicians normally remove the G or Y wire from the thermostat, then jumper or touch the G or Y wire to the wire that's connected to the R terminal. If the indoor or outdoor unit engages, then the t-stat is/may be the issue. Lots of help out there for testing/bypassing a thermostat. If you're t-stat is battery operated, there is probably an issue that's at the inside unit, like a low voltage short that opened the low voltage fuse, or many other reasons that would cause this scenario. I'm not sure if this will help you, bit you may need a technician if it's not the t-stat.
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
Intermitant temperature
Check to make sure your thermostat works right by monitoring the warming up of your engine. With a completely cold engine, start and run the engine for a few minutes, then put your hand on the top radiator hose to monitor if and when it gets warm as the thermostat opens more and more and note the gauge reading( if it works) the top radiator hose should be unbearably hot within 5-8 minutes. If the therm. opens right it should close right aswell, staying open a little while eventhough the radiator may have cooled may be what you are experiencing causing the rapid cooling and is nothing to worry about. The Hose should not get warm very soon after starting the engine. Regarding you gauge, lets take one step at a time, verify proper op. or the therm.
Jan 20, 2009 | 1986 Toyota 4Runner
Cools for a while ... keeps running but stops cooling.
If the refrigerant has been accurately charged and diagnosed, I would look for an air restriction. Check your filter first of all. It sounds like it may still be trying to freeze up. Make sure all the vents are at least a little open and the return grill is not blocked. In the Rocky mountain region we like to see around 44- 50 deg. at the vents. 65 would tell us that everything is not ok.
Jun 16, 2008 | Carrier 38CKC060 Air Conditioner
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
Mitsubishi WS-48613 48" Rear Projection Television Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
