Question about JBL CREATURE II Computer Speakers
Subwoofer problems The Subwoofer does not work at all except for buzzing sound, sat's are working but again with weird sound modulations. Seems like and internal problem, but Im not sure if there might be an easy way to fix this..
I've got the same problem it just suddenly stopped with working even if i put it on full the sub is working mininal.. any solusion?
Posted on Jul 01, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there!
First Things First::
1) RMS quick your sub., if you got extended warranty, for a replacement. ( this is a tipical problem for this spk.) they are aware of this.
2) you can check if something is doing interference on your room , like TV, Microwave near, or other electronic devices.
sometimes this cause extrange problems on sound. SOMETIMES.
Posted on Mar 07, 2008
What is the buzzing in my subwoofer?
It has being a long, long time since I've work with a subwoofer.
Check to see if it's making ground inside the subwoofer. Not sure if this will fix it, but it works in mine.
Dec 19, 2015 | Audio Players & Recorders
Microphone Problems
So people are hearing you but the sound is distorted. Change the mic and keep it farther away.
Feb 09, 2010 | EliteGroup P43T-A2 Motherboard
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
Buzzing sound from woofer when I plug in
If the woofer works fine when plugged into any other port, I would say that you have a connector on the receiver that has a loose connection or possibly a cold solder joint (poor or broken solder joint). RCA jacks can be stressed quite a lot especially if you use cables that have very tight connectors. The female RCA jack gets wiggled or twisted when trying to remove a cable and this causes solder joints to crack. I would have a look at that connector on the receiver..
Mar 02, 2017 | Panasonic CT-35SF23 35" TV
Terrible distortion from Sony Dav-x10 2.1 subwoofer
its not broken just turn the cut off frequency to level and the volume of the sub lil bit higher and it should work fine.
Nov 11, 2008 | Sony SA-W305 Subwoofer
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Buzzing Cerwin Vega LS-12 Subwoofer
Generally, a buzz from your sound equipment indicates some sort of nearby EMI. The normal culprits and.or possible fixes that I've found are:
- Remove any other electronic devices plugged into the same outlet as your subwoofer
- If the woofer is on a power strip/surge protector, remove it and plug directly into the wall
- If there are any nearby wireless devices (cordless phiones, WiFi eqiupment), disconnect/power down them
- Try connecting different speaker wire between the woofer & the receiver
- Try turning off all other eletronic equipment with the exception of your receiver
Let me know if any of these help and good luck!
Nov 27, 2007 | Audio Players & Recorders
Subwoofer has a constant vibrating tone that will not go away
I suspect that what you are hearing is the 60 cps of the mains. If the humming sound is coming the subwoofer itself, then it is possible that you have a defective/leaky capacitor in the power supply section of the subwoofer. In the subwoofer, if the buzzing sound is coming from anywhere else other than the speaker itself, then it is possible that you have a loose transformer again in the power supply. Unless you are comfortable working with testers and soldering irons, I would suggest an electronics technician who should be able to diagnose and fix it for you.
Apr 02, 2007 | Dell Powered Subwoofer Set A425 Computer...
Loud Buzz
If the sound is more of a low hum than a buzz, you probably have bad capacitors in the power supply...Time to take it to a shop.
Sep 21, 2006 | KLH ASW10-120 Subwoofer
JBL CREATURE II Computer Speakers Logo
323 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
