Could hear the relay 'clicking', but no power to horn itself under the hood. Checked fuse panel and apparantly the horn fuse wasn't making good connection. "Wiggled"/made sure all fuses were good- now horn blows good and strong.
Your horn buzzer is either broken, or it is not getting power. The click you hear is the horn relay. It is good that you can hear it.
To diagnose the problem, locate the horn module. It should be behind the grill in the front of the car. Remove the power wire. Get an assistant to press the horn button while you measure voltage in the connector. If you have voltage, replace the horn. If not, find out why there is no voltage. It could be a blown horn fuse or a broken wire. Good luck.
Hello and Welcome to FixYa.com
Clicking noise is the relay that is when you push the horn button. if this clicking is on it's own let me know.
you may have a bad horn all electric works
Thank you for using FixYa.com
Regards, Lee Davidian
Your FixYa Expert
