Question about Emerson MS3100 3-Disc CD Changer
Speaker Problems Like a few others here, one of the speakers is not functioning properly. The left output works 100% of the time, and the right side does not. If you isolate the right side, and turn the volume to max, the song playing can faintly be heard. Is there something I can do about this?
  • Paul Deane Feb 29, 2008
    Jim,
    First, thank you for the timely response. Both of the speakers are working properly as discovered by switching them. The problem must be the right channel audio amplifier. Is there a way I can fix this?
  • 2,130 Answers
Can you swap speakers and see if the left working speaker works when plugged into the right output?
If it does, then your right speaker is bad or the right speaker cable/plug may be bad.
If the working left speaker doesn't work on the right output, then I would suspect a problem in the right channel audio amplifier.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 29, 2008
  • SHARCNET-USA
    SHARCNET-USA Feb 29, 2008
    Yes, it can be fixed. The audio amplifier is either defective or perhaps there is a bad solder joint on the terminals.
    The audio amplifier is usually a module with a metal tab that is bolted to a piece of metal, like the chassis. Since this is a stereo, there will usually be two of these (for right & left) unless both channels are in one package.
    I'd locate the right module and see if the solder joints look good. If they look okay, then the module will need to be replaced. You'll need to locate the part number on the module package and you can try to contact a company like www.mcmelectronics.com
    and see if they carry a replacement part.
    I would not try to replace this part unless you have adequate desoldering/soldering experience. In this case, you'll need to take it to a repair facility to be repaired.
    - Jim
Need to wire up a factory radio plug for 2003 chevy tahoe z71 with bose premium system. need to know what wire gose in what pin in the plug. SOMEONE PLEASE HELP ME!!! PLEASE!!!
Connector Part Information
12110088 (Except UQ7 w/o Y91)
24-Way F Micro-Pack 100 Series (GRY) (Except UQ7 w/o Y91)
15428074 (UQ7 w/o Y91)
24-Way F Micro-Pack 100 Series (GRN) (UQ7 w/o Y91)
Pin
Wire Color
Circuit No.
Function
A1
ORN
1044
Radio Class 2 Serial Data
A2
Not Used
A3
PPL
493
Rear Seat Audio Enable Signal (UQ7 w/o Y91)
A4
RED
1486
FM Composite Signal (UQ7 w/ Y91)
A5-A7
Not Used
A8
TAN
201
Left Front Speaker Output (+) (UQ3/UQ5)
A8
TAN
511
Left Front Low Level Audio Signal (+) (UQ7)
A9
GRY
118
Left Front Speaker Output (-) (UQ3/UQ5)
A9
DK GRN
1947
Left Front Low Level Audio Signal (-) (UQ7)
A10
LT BLU
115
Right Rear Speaker Output (-) (UQ3/UQ5)
A10
BLK
1946
Right Rear Low Level Audio Signal (-) (UQ7)
A11
DK BLU
46
Right Rear Speaker Output (+) (UQ3/UQ5)
A11
DK BLU
546
Right Rear Low Level Audio Signal (+) (UQ7)
A12
BLK/WHT
1851
Ground
B1
ORN
340
Battery Positive Voltage
B2
Not Used
B3
PNK
314
Radio On Signal (UQ7 w/o Y91)
B3
DK GRN
145
Antenna Enable Signal (UQ7 w/ Y91)
B4
BRN/WHT
230
Instrument Panel Lamps Dimming Control (w/ Y91)
B5
BLK/WHT
1851
Ground (w/ Y91)
B6
GRY/BLK
2334
Radio Mute (UQ7 w/o Y91)
B7
Not Used
B8
BRN
199
Left Rear Speaker Output (+) (UQ3/UQ5)
B8
BRN
599
Left Rear Low Level Audio Signal (+) (UQ7)
B9
YEL
116
Left Rear Speaker Output (-) (UQ3/UQ5)
B9
DK GRN/
WHT
1547
Left Rear Low Level Audio Signal (-) (UQ7)
B10
DK GRN
200
Right Front Speaker Output (+) (UQ3/UQ5)
B10
ORN/BLK
1546
Right Front Low Level Audio Signal (-) (UQ7)
B11
LT GRN
117
Right Front Speaker Output (-) (UQ3/UQ5)
B11
LT GRN
512
Right Front Low Level Audio Signal (+) (UQ7)
B12
Not Used
Oct 20, 2015 | Cars & Trucks
I have a Rowe AMI 100 CD jukebox. It plays about 3 song and then right upper speaker goes out. Is this a speaker problem or something else?
You could have connector problems on the speaker crossover network located inside the amplifier compartment on the opposite wall from the amplifier. Typically the solder joints go bad where the connectors are soldered to the board. Usually a simple resoldering can fix it. There could also be problems with the connectors at that particular speaker itself.
May 01, 2014 | Wurlitzer Jukebox CD Player
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
May 08, 2011 | Audio Players & Recorders
Front left speaker stopped working. I use the system with my computer (full volume on computer), and usually half volume on the speaker. I've had the speaker for a few months now. I looked the wiring to...
You 'looked' at the wiring but have proven it is defective by swapping the speaker independent of the wiring. What's next? Replace the bad wiring.
What happens when you put a working speaker and wire on the front left output?
Apr 14, 2011 | Samsung HTC550 Theater System
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
I can not hear sound from right speaker but left speaker is normal. My source and wire is working properly.
Plug the speakers into a different source, and try them -- for example, a notebook computer.
It could be the case that your current source is "panned-100%-right", or somehow is "muted" on one output channel.
Aug 09, 2010 | Bose Companion 2 Computer Speakers
Left speaker is not working on my 2.1 speaker system...
A few things can cause this to happen. First we should check the computer. Take a pair of headphones or other speak set and check if sound comes from both sides. If to then the computer output is correct, else the computer is channeled to output to one side.
To change sound settings, if this is windows, go to your control panel and look for sounds option. In there you can change speaker settings, change volumes. On the volume control you can balance the speaker output. center the slider to make both correct.
If sound is coming from the PC correctly with a test object you will need to check your speakers for a fade option, not many have this it is just a suggestion. If no fade option exists, make sure the plug is totally seated. Improperly seated plugs will cause only 1 channel to be outputted or none.
If all the above does not help then check the cabled leading form the computer to speakers for damage as well as checking the wire between the left and right speakers for damage. Many times the output lead from the right to he left gets damaged from stress or other things and will stop output. Wiggle and pull the wire gently in each direction if they don't physically look damaged to see if sound is produced. if it is then the wire is internally damaged or loose from the speaker.
good luck
Mar 14, 2010 | Altec Lansing Audio Players & Recorders
How do i properly connect the wires for a JVC SX-SW5th
Connect the speaker output of the reciever to the input of the speaker. Make sure you connect negative receiver output to negative speaker input and positive receiver output to positive speaker input.
Sep 15, 2009 | Audio Players & Recorders
Left Channel Not Working.
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
How do you know the receiver's Left channel isn't the fault? Sounds like a source issue.
Jan 04, 2009 | Bose Acoustimass 16 Speaker
Emerson MS3100 3-Disc CD Changer Logo
226 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
