Question about Canon Pixma MP500 All-In-One InkJet Printer
Printing When I print pages I have a long thick black line of ink going down the middle of the paper on the back side. I've tried deep cleaning and it doesn't seem to solve the problem. I've had this printer for about 2-3 years now. and this just started happening about a month or two ago. Can you help me with this problem? would appreciate it. Madden Page
  • 2 more comments
  • Anonymous Mar 02, 2008
    My Canon PIXMA MP500 occasionally leaves about a 1/4" black strip down the back side of the paper. Reprinting the page helps. The problem comes and goes. I followed all of the maintenance steps including cleaning the bottom plate. No relief.
  • Anonymous Jul 15, 2008
    I'm having the same problem -- tick black line on the reverse side of the page -- don't know what to do.  flowergarden@surewest.net
    Would love to know how to fix this problem.
    Thanks!!
  • dmallow7286 Jul 25, 2008
    thick black line going down middle of underside of printed page - tried cleaning procedures, changing cartridges, everything ... please help
  • olsoncrew Jul 30, 2008
    I get the thick black line as well. I think it has something to do with the large roller on the roller bar which pushes the paper out/pulls it in. If I clean that roller off through the paper shoot, it has gone away for a short time, but returns. Can the rollers stick, be cleaned or replaced in any way? The printer works great otherwise.
When you have this problem of your printer disconnect it remove ink catridge colector and clean .
Posted on Jul 31, 2008
Canon pixma ip1000 black ink stop printing suddenly
Based on your explanation I will try to help.
Your ink tank had run out. You can refill it through the bottom of the tank or just simply replace your ink tank.
Aug 11, 2017 | Canon PIXMA iP1000
Printing
No black line while you scan, but it only appears while you are printing?
Mar 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Cannon MP500, new ink now printing black line on back page
Got to Printers and Faxes in Start, Right click on the icon for the printer, click properties, click maintenance and try cleaning the backing plate from there.
Jan 19, 2010 | Canon Pixma MP500 All-In-One InkJet...
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 16, 2008 | HP DesignJet 450c InkJet Printer
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Dirty print
Try to print in high quality paper a thick paper
Apr 22, 2008 | HP LaserJet 1150 Printer
Bad printing
just for info my printer wasn't printing much of anything black and color. If you hold down the middle button till the light on the top blinks twice it will give you a color test page. it should give you a grid to the right and to the left it should have the letter H and two blocks. If it doesn't you hit the middle button until the light blinks once and that is the cleaning. I have had to do almost 25 cleanings just today to finally get some results. Hope this helps you.
Dec 04, 2007 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
248 people viewed this question
old marine
old marine
