Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
"Poof" Washing Machine Began Smoking, now displays no evidence of getting power!"
I have a GE HARMONY PROFILE Washing Machine, and a few days ago I showed an error message of a broken Clutch Coupling. After doing some research I saw this message is not unusual and that by doing a reset sometimes fixes the problem...and for a few loads it did!
This morning however I was finishing a SMALL load of laundry when I heard a "POOF" and I want to be very clear on this sound so that others reading this can understand the sound. It WAS NOT a knock, bang, grind,pop, or shatter, it was a VERY VERY loud "POOF" much like a gas stove sounds like when it ignites.... but this was 10 times louder.
I immediately ran to the wash room to find the unit emitting smoke from the top back and also from the tub area. The smell was of burnt rubber or plastic. I quickly unplugged the unit and made sure it was not on fire. I let it set for about 5 min, then I plugged it back in. NOTHING. No light up or picture on the LCD screen, no sound from the buttons, NOTHING. It is like there is absolutely NO power getting to the unit. What could this be. I have been here before and received great support concerning my dryer which needed a blower motor, I am ALL EARS on what could help this situation.
Thank You,
gamblehouse2003
  • gamblehouse Mar 01, 2008
    Took the unit apart Main PCB Assembly, is scorched on the inside, looked into replacing cheapest $202.00 plus shipping! I am afraid it might have fried the LCD screen or something else. Any ideas?
  • Anonymous Aug 21, 2008
    gamblehouse,
    Had exactly the same thing happen. Kept resetting the unit and then finally..Poof...nasty smell and no display. After a complete teardown and reassembly, discovered the "circ filter" ??? was smoked. This is part 241 on the parts explosion. Now, I still don't know what is the contributing factor to how this finally overloaded this part or if it was on its way out, but I have totally cleaned, greased and reassembled the washer and I'm willing to roll the dice on a new filter. If anyone can offer an explanation on this failure mode, it would be appreciated. Thanks.
  • 958 Answers
Maybe not...try replacing the main pcb first. but heres a tip...look at the plastic holder of the main board, do you think water could drop inside the board?...if you think so then better think of a cover that could prevent the water from entering the board. coz that's what happened before... sometimes suds overflow and make their way to the board thru the wires or simply dropping to the board directly... i hope i was able to help....
Posted on Mar 07, 2008
Tip
GE Profile Harmony DPGT750GC
Are you having problems with your GE Profile Harmony but don't know where to start to troubleshoot? Let the dryer do it for you, here's how:
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
The system will give you a description of possible hardware failure and troublecode.
Replace the failed piece of hardware and plug your system back in. It will go through a boot-up sequence and verify that your machine is working once again.
on Apr 30, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Tip
GE Profile Harmony DPGT750EC (Electric)
on Apr 30, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer not heating
inverter board may be bad. how long have you had the machine
May 07, 2010 | GE Profile Harmony DPGT750EC Electric...
How do you remove the washer door
Thanks very much, but my husband found a way to remove the lid on the washing machine. There are 3 screws on each side of the lid that have to be unscrewed in order to remove the lid.
Jan 13, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
I have a GE Profile Harmony washing machine,when I go to turn it on a notice pops up ther is a problem with this unit,what do I do?
What does the notice say? Also, it's important to enter the Field Service Mode:
This will tell you what exactly is going on with your washer. Good luck!
Mar 07, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
WASHERS WILL START
GE Profile Harmony
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
Let me know what the errors are I can help..
Mar 16, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
640 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
