Question about Dell Dimension 4600 PC Desktop
Control-alt-delete When I press control alt delete I get a square in the lower right that looks like a chart of ram usage instead of rebooting the computer.
  • beez56 Feb 29, 2008
    Thanks for answer so quickly. You're right, I'm using XP. How do I re-boot if the mouse is hung up or something? I thought I had been using control-alt-delete since I got XP, I just started having this problem recently. Thanks again, beez56
  • beez56 Mar 02, 2008
    Thanks, Matt, but that doesn''t work if the mouse is stuck in place and won't move. Do I have to just shut the computer off and start over? Thanks again.
    Novelist:
  • 155 Answers
It sounds like you're using XP. That little 'chart of ram' is the system tray icon for the Windows Task Manager. If you click on the icon, or right click and select restore, the main window should appear.
That's what Ctrl+Alt+Del does nowadays. It is only in older,pre-XP versions of Windows that a double Ctrl+Alt+Del performs a reboot.
Matt
Posted on Feb 29, 2008
  • Matt UK Feb 29, 2008
    No probs ikenfixit...
    If you start the Task Manager (Ctril+Alt+Del), go to the menu bar, select 'shutdown' and then cleck 'restart' from the drop down list.
    Matt
    Scholar:
  • 163 Answers
Thats Task manager and if you have Windows 2K , XP or Vista they will not shut the unit down w/these keyboard options.
  • Ken LaDere Feb 29, 2008
    OOps sorry Matt UK We must have posted at the same time.. ;)
Boot error - requires control alt delete to recover
Bootconfig might be bad for windows not to start. Or could be a hard drive problem. Windows startup repair might work or you might have to reinstall the operating system. If this does not work then possible the hard drive has problems.
Nov 26, 2012 | Computers & Internet
I just installed a samsung SH-s222a dvd writer and it's not reading a dvd or a cd. I have a desktop with an XP home edition. Thanks.
Hi os4560
It might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned.
Best regards ,
fanaudi .
Sep 13, 2011 | Samsung SH-S222A DVD-RAM Burner
Memory full while i'm browsing
before this happens open task manager (press ctrl alt delete simultaneously).
under performance tab see cpu usage and memory.
cpu usage should be about 2% normally.
memory should not be full.
if cpu usage seems high then a virus is trying this act or you have unwanted programs which you my end from startup.
second case is of some problem in ram
Jun 17, 2011 | Computers & Internet
Blackberry bold 9000 rebooting solution
If your BlackBerry Bold 9000 series device is frozen or not responding, you will probably want to reset the unit. Here are the different types of resets that can be perfomed in the order they should be tried.
Soft Reset
Press ALT + RIGHT SHIFT(CAP) + DELETE.
Double-Soft Reset
Press ALT + RIGHT SHIFT(CAP) + DELETE . The screen will go blank for a few seconds. When the screen comes back on, immediately press ALT + RIGHT SHIFT(CAP) + DELETE again.
Hard Reset
If none of the above works, pull the battery out of the unit for a few seconds, then reinsert it.
May 13, 2011 | RIM BlackBerry Bold Smartphone
My bb is getting rebooting
If your BlackBerry Bold 9000 series device is frozen, rebooting or not responding, you will probably want to reset the unit. Here are the different types of resets that can be performed in the order they should be tried.
Remember your data will we wiped. So make a backup.
Soft Reset
Double-Soft Reset
Hard Reset
Mar 12, 2011 | RIM BlackBerry Bold 9000 Smartphone
Hi . Iam ASHOK . my Laptop hava some problem (BOOTMGR IS MISSING PRESS Ctrl+Alt+Delete .) my laptop configuration is intel 3i Pro, Hdd 500 gb , Ram 4gb , OS is Windows 7 . place help me ...............
Hi Good day!! There might be a corrupted files in your windows (BOOTMGR) you will need a windows 7 CD
* Insert your Windows 7 disk into your DVD player and restart your computer.
* The next screen you see should have the Language, Time and Currency and Keyboard boxes.
* In the lower left side there are two options: "What to know before installing Windows" and "Repair your computer."
* Click on "Repair your computer"
* Windows will then try to find the installation directory for Vista or Windows 7, depending on what you have.
* Next up is a screen with a box called Recovery Options. Click the first option, Startup Repair.
* You'll see a Startup Repair box with the message "Startup Repair is checking your system for problems..."
* When it's done, it will prompt you to reboot. If there is more than one problem it may reboot again to continue repairing.
* At this point, you can remove the DVD, reboot and everything should be working.
Thank you for using FixYa
Please accept if my solution helps you!!
Nov 08, 2010 | Dell Computers & Internet
How do I reboot my acer laptop with my copy disk?
When turning your laptop on, before Windows starts booting, a splash screen appears first (usually with the logo of the manufacturer). Look on the splash screen (usually at the bottom) for a key (usually F10 or F11), assigned for System Recovery CD/DVD with the laptop. or 1.Press the start button from the start menu depending on your operating system(win 2000,xp) 2.Press Ctrl+Alt+delete combination from the keyboard. 3.If you have a power button on your laptop keyboard,it could also be useful by pressing and hold it down for few seconds N.B: "Ctrl+Alt+Delete" can exit you from usage and trigger a reboot or shutdown. Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up. Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot. Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately. Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually. A few seconds should do unless you have additional problems.
All the Best!
Sep 12, 2010 | Computers & Internet
My cap lock will not let me type in lower case letters and every letter that I must hit twice will stop after my first letter befor I can go on the same with foward and back spacing
You might have enabled the Windows "Accessibility" features, i.e., instead of pressing CTRL-ALT-DELETE at the *SAME* time, you can press CTRL, release it, press ALT, release IT, press DELETE, release it, to emulate the three-finger salute.
Reboot your computer, to start without the "Accessibility" feature active.
Also, try a different keyboard.
And try the keyboard in a different computer.
Jun 12, 2010 | Gateway 2520915 Keyboard
RAM usage seems high. Even right after startup,
it's just normal;but try to figer out if you are running memory intensive program disable them if you don't need it and moreover scan your PC with a good antivirus for anti malware they are usually memory hungry program.
i recommend to use A-squared anti malware from www.emsisoft.com.
here is the link
http://www.emsisoft.com/en/
hope this helps you
Dec 07, 2009 | Dell Inspiron 1525 Notebook
My CPU usage is constantly a hundred percent.
When system boots click start button > run > type in box "msconfig" without quotation marks. Click on "selective startup" Go up to the startup tab > click on disable all. Click on apply and ok, reboot. When computer reboots, see if the processor is still running at a hundred %, if not then one of your start up processes is the culprit. You can go back into msconfig and check just those processes that you absolutely need to start up, like a third party wireless controller, anti-virus, malware/spyware, etc., but most of those startup processes you dont need to boot up.
Sep 18, 2009 | Compaq Presario Notebook
Dell Dimension 4600 PC Desktop Logo
85 people viewed this question
Alun Cox
