Question about Technics SL-1210M5G Turntable
Sl-1210mk5g's just brought some 8 months old cant work out how the lids fix on
  • djonit Feb 29, 2008
    how do the lids fit on?
Because DJs don't like to have the hinges on they usually just rest the lids on top. I'm not sure if the M5Gs come with the hinges. I know that the M3Ds did not. Check to see if your turntables came with the hinges, if they didn't you can order some and install them
Posted on Aug 28, 2008
The 1210m5g comes with hinge-free lids.
If you search for 1210m5g hinge-free dust cover you will see this mentioned.
Posted on Jun 08, 2008
    Novelist:
  • 155 Answers
It should be fairly obvious. The only thing I can think of it that the hinges are missing (these slot in to both the lids and the turntable and are easily lost if someone has been using them with the lids off).
If they are missing, it certainly would make it difficult to figure out!
Matt
Posted on Feb 29, 2008
Why doesn't it charge or turn on?
Hi if u brought it new it will b under warranty take it back for repair cheers
Feb 25, 2016 | Nextbook 8" 8 GB Wi-Fi Black Tablet
Will not spin or drain tried unplug and lid switch is fine fill ok
Susan call your service repairman the warranty should cover the fix .
Dec 09, 2015 | Washing Machines
My Whirlpool Cabrio washer wtw555oxwo turns on, lid locks, then the lid lock light starts flashing and the machine does nothing. Just replaced the lid lock, but nothing has changed. Any suggestions?
adjust the lid lock switch?? seems to me that lid lock mech is not moving far enough to properly be sensed by switch
if machine is over 8 months old id suspect rust in lock arm as cause
Jul 22, 2015 | Whirlpool Washing Machines
My 6-month old topload WF 8702CPG keeps stopping in the middle of the cycle with the code LE. Going crazy tyring to figure out what's wrong. Error code not in the manual. What does it mean and how do I...
this means the lid safetey switch is a bit out of adjustment LE means Lid Error. if you press down on th lid it might take the error away while you are pressing. without breaking the lid. This will prove the lid error. A warranty call may be necessary . 6 months old must be under warranty Good Luck
Sep 11, 2010 | Washing Machines
Have a Sager 9280. One month old. Closed lid on
This computer should be returned to the supplier to have it repaired or replaced. Do not try to fix it yourself because it most likely void your warranty.
Aug 11, 2009 | Computers & Internet
Broken glass in top of TR 875 Breadman machine
Hi-
I saw your post and had the same problem. I unscrewed the lid and removed the pieces of glass measured and asked my local glass store to cut me a new circle. I brought them the sample glass (so they knew what kind to use) and they cut 5 1/8" circle that fit perfectly. It was $5. Hope you haven't tossed your yet. Thanks,
Heather
Jun 23, 2008 | Breadman TR875 Bread Maker
How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
Mar 25, 2008 | Technics SL-1200MK2 Turntable
Lid locked
Sounds like a falled board in the machine itself. At 8 months old, is your warranty still in effect? If so, may want to call the Searsman. Good Luck!!! Jim
Sep 03, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Technics SL-1210M5G Turntable Logo
328 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
