Question about JVC Televison & Video
JVC LT-32DY8ZJ FUZZY PICTURE
JVC LCD LT-32DY8ZJ, Picture fuzzy, tried changing contrast etc, but no go.
It looks like peoples faces are made of rubber.
Fixed my problem, took it back, got refund and bought a different telly !
Posted on Mar 10, 2008
Auto-dimming problem
It depends of the set--may have a light sensor built in and if so when light in the room changes the brightness on the TV and contrast will vary.
May 30, 2012 | Vizio Televison & Video
Dual Monitors - why does my second monitor have bad picture?
As long as something isnt broken, using the HDMI and the D-Sub should be fine. From your fuzzy pictures I suggest that you want to double-check your cables.
Have you tried to switch it? If you put the second monitor on the D-SUB and the picture is still faulty, its very likely the problem is your monitor.
Dec 29, 2011 | LG 22" FLATRON LCD Monitor
JVC 32 inch LT-32DY8ZJ T turns on...shows green light....then turns to standby then back on then off again. Can this be repaired?
Good day..
That problem is usually cause of bad capacitors on the power supply section..
As you stated your TV works fine and after a minute the red light comes on...
That symptoms is cause of bad capacitors..Normally bad capacitors can check visually if the capacitors look like leak/bulged on the top that is the indication of bad one but not all bad capacitors are bulged some are not so in that case you have to used a special meter called capacitance meter..
This is the sample picture of bulged capacitors:
Dec 05, 2011 | JVC LT-32X575 32 in. HD-Ready LCD...
The picture is very fuzzy (pixelated) when you first turn power o
this problem occurs usually in the power supply change or check the power supply borad
Dec 18, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
Sep 12, 2009 | Insignia 42" LCD Flat-Panel HDTV
New flatscreen Sanyo tv. Picture is to big for the screen
use the picture button to change the shape, Most likely you have it set to picture 3 which would cause that.
Jul 04, 2009 | Sanyo DP32648 32 in. LCD TV
LCD screen Olympus Stylus 1010 snowy and fuzzy with lines
This is a issue with just the LCD it needs to be replaced.
May 25, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Just purchased tv and the quality of the picture is still fuzzy tried to mess around with the resolution but it still isnt very sharp at all
The TVs produce picture using entirely different methods. Usually the colors and especially level of black color are better on plasma, LCD will have some trouble various shades of gray and black especially shading on peoples faces etc.. This is not a defect in the LCD just a limitation in current technology.
Apr 26, 2009 | Televison & Video
Fuzzy picture and in a different language
click on "menu".
then move to the "hand" while clicking on lightview
then clivk select/auto
it should automatically select the third from above
then move to the top while clicking on lightview
and now change the language with the "sun" buttons
Dec 17, 2007 | LG Flatron L1715S 17" LCD Monitor
Televison & Video Logo
277 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
