Question about LG 50PX4DR 50 in. Plasma TV
Split Screen How does it work? Do you need two inputs from the cable company.
How to repair a plazma tv with a split screen image
Posted on Apr 08, 2008
TVGOS (TV Guide on Screen) stopped working on Time Warner.
split your input cable line and connect one end to your digital input and the other to your
analog or air input.
Jun 28, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Split screen question
To get a split screen working on this set, you will need to do the following steps.
1. Put a splitter on the incoming cable.
2. One side will go to the digital cable box and one to the tuner on the television. (Ant A)
3. Hook the digital cable box using the video out from the box to Input 1 on the set.
That should do it now select your digital cable on Input 1, and then select the split screen source as Antenna A. You may have to switch sources to select a different input.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support.
May 16, 2009 | Pioneer PRO-620HD 58" Rear Projection...
When i try to connect my xbox 360 to my Vizio hdtv it doesnt not recognize the connection. I have tried replacing the cord to no avail
I have a Vizio 37' tv with an Xbox 360 and it works fine. I am a Cable repair tech, hook up the xbox using the composit cable first RCA these are the red white and yellow cable to a non high def input on the tv, if that works check the settings in the xbox, there is a screen that will allow or enable HD quality pictures. Also check the Xbox cable itself. at the Y there is a small swiitch that goes from componet to composit you can only get HD if you use the Red Blue Green cables, then make sure you have the TV input set to that input other wise you will have only a blue screen. If that does not work, Hell, call the cable company if you are a customer, they should send someone out to show you how to connect it, and they might not even charge you, we don't, but I work for a smaller company, not ComCast or Cox, If you want to email me you can kml39@yahoo.com, good luck
Jan 10, 2009 | Vizio L37 Television
Pioneer 501-HD 53 Rear Projection TV- No Picture or Sound
your input board might be bad, does it work on any other inputs?
Oct 11, 2008 | Pioneer PRO-510HD 53" Rear Projection...
LG 42PC3D plasma television -- screen split down the middle
Our 42" LG picture is also split down the middle. It doesn't matter if it is cable or a DVD. I would love to know if anyone has found out the solution to this prob. The TV is only 3 years old...
Jun 19, 2008 | LG 42PC3D 42 in. Plasma Television
JVC Television 56" in Digital Mode
somewhere in the tv's menu there will be something called autotune or channel settings. while in that part of the menu you should find something to change settings. also there are many inputs on the back of big screen tv's, you might try a different input like cable/antenna for instance. it may take a two way splitter to split the signal for both digital cable and analog cable. by next february the analog part of the cable may not work anyway.
May 02, 2008 | JVC AV-56P575 56" Rear Projection...
Ah split screen just another way of getting two picture in one screen, or sport for he and Opra for her.
Fisrt you must understand what split screen is, it is taking two information from different source and sending the info to the micro to devide the info for two seperat image.
Well something like that but I know you were inpress,
Yes you can. Take the main source you or using I would say the TV box in cable connection or av1 and then your DVD or and VCR to source av2 or 3. When presing split screen or pip you will get one screen showing the main source your tv box and the second your dvd (or VCR) in the source input solector you should be able to change the second amage input with input solector and the tv box change the other.
Oh what a butiful life aint it.
Try this with 7 different source, Cable, satelite, fta, dvd, camera, gaming sytem, and computor,... well that another chapter.
What about Bob
Feb 29, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Only if you have 1 Ant input, if you have ant 1 & 2 then you don't need a vcr for split screen.
Feb 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No signal on main tuner
can you connect comcast to another tv that should tell you if it's the tv tuner or cable company.
Nov 14, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Split screen from DVD player, cable is fine no problem
It is not clear where you say input is from cable, do you mean the Scart input to your Sony TV? Do not use Progressive scan(p), as this is not interlaced. The normal TV requires an interlaced(i) picture of 50 half frames per second giving 25 complete pictures per second to reduce flicker. Some TVs and projectors and all monitors accept Progressive scan.
Oct 15, 2006 | Sony KV-32S25 32" TV
LG 50PX4DR 50 in. Plasma TV Logo
361 people viewed this question
