Question about Acer-Veriton-M410-US3800P AMD Desktop PC - AMD Sempron 2.2GHz, 1GB DDR2, 160GB SATAII, DVDRW, Gigabi
Install question I want to install a cdrw in the 2nd drive bay. How do I remove the front bezel?
  • LSIT Feb 29, 2008
    The PC is an Acer Veriton M410 desktop.
  • Anonymous Nov 05, 2008
    i have about the same problem when installing cd drive. I am able to remove the front bezel but there is still a piece of metal blocking the 5.25 bay after the front panel is removed. Anyone knows how to remove that? i tried to remove that but failed. will post some pics if needed
    thx all
  • 112 Answers
Take the side of the case.
You should be able to get to the back of the slot where you want to install the CDRW.
Just push the bezel in the middle and it shoudl bend releasing the plastic catches securing it in the slot.
It is plastic and you are going to throw it in the garbage so dont worry about pushing to hard.
Let me know if this helps.
Posted on Feb 29, 2008
How to replace CD-ROM drive
In most cases, yes. Sometimes the drive can be removed by pulling it back into the case's motherboard area, then the new drive installed and pushed forward to be flush with the front of the bezel, but not usually. It is usually easier, if the hardware allows it, to remove the front bezel, unplug the drive's connectors, loosen the mounting screws or other gizmos, and push the drive out through the front. Reverse the procedure to install the new one.
Oct 07, 2014 | Gateway 3250S PC Desktop
Installing a dell latitude D series External Media Bay CDRW DVD RW Drive PD01S
If you have a complete External Media Bay drive (drive, case, cable), then you can plug the connector to the laptop or docking station, and turn the laptop on. The laptop will detect it automatically.
Feb 26, 2014 | Computers & Internet
Window on drivers side froze and fell down and won't roll back up. How to take door panel off to fix the window
  1. Disconnect the negative battery cable. Important: When removing a door trim panel or switch plate, disconnect the negative battery terminal. This will eliminate the possibility of shorting out the switch if you use a screwdriver, an awl, or other metal object in order to remove the switch from the harness.
  2. Remove the window regulator handle, if equipped.
  3. Remove the front door warning reflector.
  4. Remove the door panel screw (1) through the hole in the door warning reflector opening.
  5. Use a flat bladed tool in order to remove the rear deck release switch bezel.
  6. Disconnect the rear deck release switch.
  7. Use a flat-bladed tool in order to remove the lower switch bezel trim screw access cover.
  8. Remove the lower switch bezel trim screws.
  9. Remove the lower switch bezel
  10. Use a flat-bladed tool in order to pry the front door switch bezel upward.
  11. Disconnect:
  1. Gently disengage the front door trim retaining clips and remove the door trim panel from the door.
Installation Procedure
  1. Install the front door trim panel to the door. Ensure that the retainers are locked into place.
  2. Connect the rear deck release connector.
  3. Install the rear deck release switch bezel. Press the bezel firmly into place.
  4. Install the window regulator handle to the door.
  5. Connect:
  1. Install the front door switch bezel assembly to the front door trim panel.
  2. Install the lower switch bezel trim panel. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the lower switch bezel trim screws.
  4. Install the lower switch bezel trim screw access cover.
  5. Install the door trim panel screw (1) through the hole in the front door warning reflector.
  6. Install the front door warning reflector.
  7. Connect the negative battery cable.
Oct 15, 2010 | 2000 Oldsmobile Alero
How to remove HDD in compaq presario sr2030nx
After removing the side cover, you will notice 4 black tabs behind the front bezel under the hard drive, bend these back just enough to let the front cover release at the bottom, then press the green square at the top to release the front plastic bezel. After you carefully pull the front off, you will need to remove the cables [power and IDE] pull up on the green tab that locks the guide screw on the hard drive and push it forward out of the case
Dec 11, 2009 | HP Compaq Presario SR2030NX PC Desktop
What hardrive for my armada M700?
Hard Drive Installation Instructions 40 gig IDE DRIVE
  1. Shut down the computer and remove Battery Pack and AC adapter.
  2. Locate Hard Drive compartment on the front panel, just left of the head phone jack.
  3. Turn Notebook upside down.
  4. Remove the one torx screw that is securing the hard drive. (A security screwdriver was provided with the computer.)
  5. Push down on the hard drive bezel on the front of the hard drive.
  6. Lift the bezel up 90 degrees to create a handle. Pull the hard drive out of the hard drive bay.
  7. Remove the 4 black screws at each corner and lift off the black tray.
  8. Gently remove the silver bracket and connector.
  9. Place connector on new hard drive.
  10. Place the black tray on the HDD. When looking at the hard drive with the label up, the black bezel goes along the left side of the hard drive.
  11. Replace the 4 black screws from step 7.
  12. With the hard drive bezel pulled down, slide the hard drive into the hard drive bay.
  13. Push up on the hard drive bezel to secure the hard drive in the bay.
  14. Secure the hard drive bay by replacing the screw from step 4.
  15. Replace the battery pack and all cables
Aug 08, 2009 | Compaq Armada M700 Notebook
Replacing power supply HP M8120N
Here is the link for the upgrade and service guide.
This one is just as easy as 1) removing the side panel; 2) Remove the four screws that hold the power supply into position; 3) Remove the power supply cables from the motherboard (NOTE: If the media bay reader is in the way, you remove the front bezel by pressing the release tabs on the bezel and it will swing open. Remove the one screw securing the bay in position, then slide it forward so you can reach the power cable to the motherboard.); 4) Remove the power supply cables from the hard drives, cd rom drives, and other peripherals inside the PC. 5) Remove power supply...sometimes there is a button to push and it will slide out, sometimes not. 6) Replace power supply, then reverse procedures.
Thanks and please take a moment to rate as fixya.
Dec 07, 2008 | HP Pavilion m8120n PC Desktop
Manual showing how to remove DVD-ROM Drive from case for Presario 5000?
REMOVE CASE SCREWS FROM REAR CASE COVER.CASE COVER SLIDES OFF FROM FRONT TO BACK.DVD IS HELD BY 4 SCREWS TWO PER SIDE DISCONECT POWER LEAD AND RIBBON CABLE YOU GOT IT,RICHARDM69
Dec 02, 2008 | Compaq Presario 5000 PC Desktop
Installing cd drive
The piece of metal is a punch out and you will need a flat head screw driver to pry it from the corner of the punch out then bend it back and forth until it release from the small connecting points around the metal, this will fatigue the metal and break away from the opening.
Nov 05, 2008 | Acer Aspire T310 PC Desktop
Installing cd drive
Hey there beisong,
In many desktop computers you need to install the drive from inside the case and slide it outward along the runner. The piece of metal you are possibly referring to, will prevent it from sliding out too far from the inside. Alternately, but less likely, there may may some quick locking mechanism on the side of the bay drive which is in place and preventing your further movement inward. In this case simply remove, usually by twisting to one side or the other to release. It may be advisable to remove both side panels to ensure there is not one on the opposite side.
Good luck and let me know how it goes.
Nov 05, 2008 | Acer Aspire E380 ASE380-UD500A PC Desktop
Installing cd drive
That piece of metal is called a knockout. It's there to block off that area as long as you don't have anything installed there, to maintain a seal for cooling purposes. You can remove it by simply knocking it out or twisting it. Once you have be careful where the tabs were attached may be sharp, use caution until you get your new drive install to block the edges.
Hope this helps.
Dave
Nov 05, 2008 | Acer Aspire™ T180 PC Desktop
Acer-Veriton-M410-US3800P AMD Desktop PC - AMD Sempron 2.2GHz, 1GB DDR2, 160GB SATAII, DVDRW, Gigabi Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
