A e g washing machine
Hi     i have an a.e.g washing machine it was working nicely for the last couple of years, suddenly it stoped , light is on but no sound of working. i need some trouble shooting hints .
  • 57 Answers
If the washer doesn't operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power or, if the motor stopped mid-cycle, the machine's overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself, then restart. Otherwise:
1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer and check the power cord. If necessary, replace the cord if you feel qualified.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person.
5) If the washer still doesn't work, the controls may be faulty. Call a service person.
Posted on Mar 02, 2008
Why do the lights throughout the house pulsate when the washing machine starts agitating?
What make and model washing machine? How far is the breaker box from the washer?
Mar 24, 2017 | Washing Machines
Hi. I have a Bush A126q washing machine, which last night, suddenly stopped working on any programme and with the start/pause light blinking. I have checked the usual suspects, pump filter, too much...
All Machines theses days are digitally controlled, which means they do a self diagnostic test just before they start. If a fault is found they usually just stop with the light blinking. To determine the exact fault the appropriate Engineer for the machine will come along with his laptop and do his test to find where the fault is. However the most likely cause of your problem if the machine is 3 or more years old is the motor brushes. Remove the motor from the machine then remove one of the carbon brushes, if its about 3ml long its worn out.
make sure before removing the motor that the machine is disconnected from the Electrical and water supply, makes it a lot easier.
Oct 27, 2014 | Washing Machines
The tub won't drain and it spins very slowly. I've also noticed, over the last couple years, some oil/rust spots on my clothes. It is a top loading washer that is over 20 years old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | Amana Washing Machines
My machine is 3 years old and used on average four times a week. It not worked hard as we work in offices, so no heavy overalls. Last saturday it stoped half way thru a washer cycle. The door remained...
Easy, scrapped it and purchased an Indesit. The cost to repair AEG was more than buying a new machine. I would suggest to anyone reading this never invest buying AEG unless you have a live in washing machine engineer.
Jan 26, 2010 | AEG Washing Machines
Same F1 Fault Code
The only action you can take is to raise your voice with other people who have faced a same issue with Whirlpool :-
http://www.petitiononline.com/cabrio08/petition.html
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
ZANUSSI ZWF1237W 2 YEARS OLD NOT WORKING
The motherboard is blown the part is covered under warranty which will take 4-5 days to come in and I have to pay for the labour.
Jan 22, 2009 | Zanussi ZWF1430W Front Load Washer
''Washing Machine''
No problem. I am here to help. Have a good day.
Nov 20, 2008 | Roper RAS8445KQ Top Load Washer
Stops mid-cycle
Hi SaviorSound,
I'm Harvey the Master Plumbr.
Your question is: You have a MDB7100AWB that has been working fine for the last 7 years. Now all of the sudden it will not complete a wash cycle in any mode (including auto clean). It consistantly stops at 85 on normal wash & at 65 on light wash and then clicks/buzzes about every 3 seconds, like it wants to continue - but never does. Any clues as to what to try? Is 7 years all I can expect to get?
Perhaps. Your d/w is stoping at the point where it should be turning on the 'heat dry' phase. This can be expensive. At this point I would be compairing the cost effectivness of repair verses replacement. Wish I had better news for you.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Maytag MDB7100AWB Dishwasher
Kenimore portable washer
ok" sounds like motor coupleing is broken
coupling is attached to motor
coupling can be replaced, you will see if you turn the motor
by hand that it's broken
make sure the power cord is not plugged into wall
take coupling and make and model of washer to
appliance parts store or order thru sears parts
Jan 08, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
