Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi WS65615 65'' Rear Projection t.v. turns on then after a minute it turns right back off.
I have done Ic's before not on this t.v. though.
I'm sure I can do this though.
Any ideas what I should replace???
Or should I just toss the darn thing.
Thank you for your help.
Mitsubishi WS65615
  • dd8380 Feb 29, 2008
    Turns on then after a minute or two it turns right back off...thx
Thank you very much I will try that tonight.
Posted on Feb 29, 2008
    Sergeant:
  • 395 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Self-diagnosis error 2-3 indicating deflection failure. Check for shorted or leaky Q5A37 part # 260P818050 located on PCB-Main. If found defective replace only the transistor instead of the Main PCB.
also if the ligt on the front keeps flashing after shut down
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
Just changed the convergence chips and now the TV turns right back off
There is a short. Be sure none of the leads on the ic are shorted together.
Jan 01, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My wt-42311 shuts off then comes back on after a few minutes.
ur power board ic inverter is about to die.
It will die sooner or later,when it dead.U get no
power period,must replace the board.
Aug 23, 2009 | Mitsubishi WT-42311 42" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi WT-46809 Vertical Deflection Failure
the vertical output IC may need re-soldering or it may be defective and need to be replaced. my guess would be bad solder on the vertical IC.
Apr 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi color problem
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 30, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi WS-55809 55 inCH tv
best way i would trouble shoot this would be to get a can of freeze from radio shack and spay the tuner if the problem comes back you know it's the tuner if not spray IC one at a time till the problem happens.
Dec 11, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Convengence problem?
the stk ic . the big amp chip has cold solder joints . resolder the ic
Nov 30, 2007 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Sep 29, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi vs-4507ca
It just click ON and OFF, right? If you hear the hight voltage noise tring start, may be the Tv has bad vartical IC or regulator IC. If you have no experience with electronic you will need a technician to halp you.
Sep 11, 2006 | Mitsubishi VS-45607 45" Rear Projection...
No Picture after it's been on a while. Audio OK.
ok you have a vert sweep problem and yes its probably connected to in a way to the "tap and fix" problem! Seems to be n intermittant connection on the vertical out put Ic or maybe even on the rgb convergence ic?? The total loss of sweep though tells me that theres two differant problems! Maybe and intemittant connection on the vert output Ic as well as bad connections on the convergence ic??.
Apr 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
139 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
