Question about Nikon COOLPIX 5100 Digital Camera
Memory card Every time I turn the camera on, the mesage "memory card is write protected" comes up, and I can't figure out how to get rid of it.
    President:
  • 423 Answers
It sounds like the lock switch on the SD card is in the wrong position. Take the card out and move the switch away from the locked position and re-install it.
Posted on Mar 02, 2008
What is mesage "memory card write protected " in nikon coolpix4500
It means that the camera 'thinks' that the Memory Card in the camera has been switched to 'Write Protect ON". If there is no Camera Menu Item to override this function then remove the memory card from the camera and check along the edge. You should find a small black or grey slider button that will move. Hopefully it will be labeled for Write protect ON and OFF.
Reinsert the adjusted card and see what happens. If the error persists then try another card. This link might help:
Good luck.
User Manual Coolpix 4500 Guide to Digital Photography Nikon Knowledgebase
Mar 02, 2015 | Nikon Cameras
Mesage "unable to use card"
SD Memory Cards have a write-protect switch to prevent image
data from being deleted. By sliding the switch to the bottom of
the card, the data will be protected. images cannot be recorded
when the card is protected. If an attempt is made to record or
delete an image with the camera, the card-locked message will
appear on the monitor.
Sep 21, 2011 | Konica Minolta DiMAGE Z10 Digital Camera
When i put memory card in it comes up write protect can you tell me why and how do i get rid of it
You didn't specify the make and model of your camera or the type of your memory card, so I'm assuming you have an SD or SDHC card.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 29, 2011 | Cameras
How do i get rid of my write protection on on the sd card
Wecome to Fixya. Memory card has a slide switch on the side or along the edges, you just have to slide it to get rid of the write protection on your memory card. Just remember that if the position nearest on the contacts is already removed the write protection on the SD card.
Thank you for using Fixya,
seancarlisle
Apr 30, 2011 | Cameras
When camera is turned on "PROTECTED CARD" comes
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 02, 2011 | Sanyo VPC-S880 Digital Camera
My camera keeps telling me that my memory card is full. I only have 14 photos in there and no smart card....how do I figure this out.
Are you saying that you have no memory card in the camera and it is telling you that the memory is full? If so, then the "internal memory" of the camera is full. If you want to use a memory card in the camera, you must get rid of the pics in the internal memory by formatting it with no card in the camera.
Sep 23, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
What does 'Write Protect' mean and how do I get rid of it?
That means that your SD card (or whichever memory card you use) is write protected and you cannot edit the card's content in any way.
Take your memory card out of the camera and plug it into your computer. There should be a place for you to change the memory card's protections that way. Sometimes, as with USB drives, there might be a small sliding lock physically located on the card which will also write protect the device.
Apr 09, 2010 | General Electric A735 Digital Camera
Hi, I just bought a camera Samsung GX 1S, and also a GB SB card "High Performance". Every single time I turn on the camera comes a mesage indicating the card has memory problems. I formated it but the...
The card you bought for the camera is not compatible with your camera! (just because it fits and looks the same does not make it a match!) try useing a regular sb card and return the high proformance card!
Jan 13, 2009 | Cameras
Error message - Memory card requires formating
Before suspecting the camera, I'd simply try another memory card in it. Memory cards can and do fail and often can behave inconsistently before they fail completely.
Jan 09, 2018 | Kodak EasyShare Z612 Digital Camera
Memory card
go to your menu section and disable the protection there.
Sep 08, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Nikon COOLPIX 5100 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
