Faded density on an HP color printer...
I'm not an HP printer guru, but have been in the business machine service industry long enough to "guess" what my customer's problem is, and I am just looking for some support or afformation of my opinion.
They have an HP 3700N color printer that even though they have just replaced all the color modules with genuine HP supplies, still doesn't print as densly as they (or even I for that matter) feel it should.
My thought is that it's probably the transfer unit (drum/belt module). I see that they are supposed to good for a general yeild of 60-75K, and this customer has no recollection at all of ever replacing it before with 135K on the printer.
Also, there is definitive consistant fading from left to right on the prints. One other thing that may be related but I found "weird" is that the header of the internal test pattern which should be "HP blue" is actually almost a light purple but the remaining color parts of the test sheet (blues/reds/yellows) seem to fine as far as color goes, the slight density problem not withstanding.
Any supporting opinions would be helpful. Thanks in advance. Jim
  • Anonymous May 15, 2008
    All new cartridges; was OK until I replACED YELLOW...THEN EVERYTHING
  • 81 Answers
I think you are on the right track with the drum unit.
Posted on Feb 29, 2008
HP all-in-one F380 only prints top half of the page, and sometimes that is pretty faded. What to do?
Replace the ink-cartridges, because they are just about empty.
When ink is pulled from the cartridge, there is just enough ink to print a "low-density" page,
or a few lines of text, but there's not enough ink to "freely" flow, on demand, to ink a full page.
Jul 30, 2011 | HP DeskJet F380 All-In-One Printer
My phaser 740 has print that flakes off when you print pictures with real dark areas. I assume it needs more fuser heat or less paper speed. The problem is I can' t figure out how to adjust either of these...
Recalibrate the colors. Flaking is sometimes caused by more ink/toner than can be fused to the media. There's a limit for the total amount of ink/toner. Yours may be set too high.
You'll need a copy of the Printer's User's Guide (also Downloadable from
Controlling Color Density
When colors look faded, adjust the toner color density to extend the life of the components.
Print and use the Color Reference Page 1 In the printer's front panel, scroll to Calibrate Colors,
press Menu and print the Color Reference Page. 2 Compare the Color Reference Page to the Color Density
Samples on page 39. Make a note of the value (-10 to +10) for each color that most closely matches the samples.
3 Adjust the density for each color: Enter the value noted in Step 2 in the Calibrate Colors menu, under Adjust Each Color.
? Decrease color density: Press . ? Increase color density: Press --->.
4 Reprint the Color Reference Page; check your adjustments
Dec 09, 2010 | Tektronix Phaser 740P Laser Printer
The red (magneta) color is nearly non-existent. I use an EMac. I have tried the ColorSync option when printing. I have set the utility 'density' to it's max setting. This has been a very good printer. ...
First, make sure that the toner cartridges have enough toner. The toners may be exhausted. In case the toners are ok, the printer requires servicing/ cleaning of lenses and mirrors inside the printer.
Please refer here to my earlier solution to this problem, which was very helpful for the users of Color LaserJet 2600 Series Printer.
Dont forget to appreciate the solutions if I could have been of any help!
Oct 02, 2010 | HP LaserJet 2605dn Printer
HP Z6100- Magenta ink density fade
there may be air bubble in ink tube assembly if u can do the priming then ok o/w call hp service provider to do this
Jul 28, 2010 | HP Designjet Z6100 InkJet Printer
Very light print out of hp p1505 laser printer is cery light even after changing tonner and cleaning scaning unit.
This could be color miss registry, even though your printer is a monochrome printer there is a sensor which determines the color density, Black being a color, and if the sensor is damaged will cause issues like fading. Make sure you are using hp original cartridges, and if the problem is still there, contact hp for warranty options, hp's tech support line is 1800-334-51440.
Jul 11, 2010 | HP LaserJet P1505n Printer
The Density Sensor is located inside the right upper door and senses the colour calibration pattern for each colour formed on the transfer drum during a calibration cycle. Press GO. Print a configuration page and then troubleshoot as an Image-quality problem as instructed in the user manual. Check the transfer guide for cracks and replace if necessary. Check the event log for errors numbered 54.00.0<X> the X indicates, 5-sensor abnormality, 4-Cyan, 3-Magenta, 2-Yellow, 1-Black. The last 3 error codes should be seen on the Configuration page.
Dec 29, 2009 | HP LaserJet 8500 Color Printer
Docucolor 12 low density
cambia reveladores y reza un padrenuestro
Oct 31, 2009 | Xerox DocuColor 12 Color Copier
Faded red / pink on HP Color Laserjet 2605
you have to clean the image mirrors you can find a how to guide on hp's web site titled "fading red tones on color laserjet2600' process takes about 30mins to do.
Nov 11, 2008 | HP LaserJet 2605DTN Color Printer
Can't color balance 2605
well, the density is actually a combination of two aspects. The original document settings, especially in color transforms. Usually, the software will have a transform specific for the printer. In my experiences, trying to tweak the printer for each print job, can cause extreme frustration. Check the software manual for settings for your printer, and perhaps you'll get closer to this solution.
Got backup?
Feb 07, 2008 | HP Color LaserJet 2600n Printer
242 people viewed this question
