It's all to do with the top screen... What happens is that when you turn the DS lite on it performs a quick check on the screens to make sure they are connected properly, if one or both are not connected properly then the unit will shut down.
The flashing of the screen shows you that that particular screen is fine whereas the one that does nothing is not connected properly, either through a loose connection or faulty screen/ ribbon.
Your best bet is to buy a new top screen (I usually get mine from ebay for around £10-£12) and fit it. That should sort out your issue.
Any further problems or questions feel free to message me via my profile page.
Regards,
SOD69
Testimonial: "thank you very much I thought it was something like that but not sure. That makes a lot of seance.Thank you again! I will buy a new top screen "
In simple terms a orange light that goes out quickly when trying to start is usually a fuse and easy to fix, by bridging or repacing a fuse. When the green light goes out and one of the screen flashes that usually indicates a loose connection or damaged screen or ribbon. This type of problem is more involved and could require ordering a screen,(but first check the ribbon connection). There are many good instructional videos on youtube. So get your Y screwdriver and good luck.
