Question about DFI 865PE INFINITY P4/A&GB L&R/1394/ATX Motherboard
No Post CPU fan works and led on motherboard works but no post
  • 2 more comments
  • cameraman22 Feb 29, 2008
    No Beeps - Power Supply Good - Memory Good - Untested CPU ( Was Working) Prescott 2.8 P4
  • cameraman22 Mar 01, 2008
    Thanks for the tip but she is still the same. I appreciate your time & effort
    Thanks much
    cameraman22
  • F1forHelp May 11, 2010
    Are there any beep indicators?
  • 298 Answers
If your getting led lights on your board but no post or no beeps. This is usually a fried processor. Sometimes motherboards have diagnostic leds on them. If this is the case, then open you owners manual and diagnose the failure by reading the leds when the motherboard turns on.
Posted on Mar 05, 2008
  • 26 Answers
Try defaulting the cmos, this is best done by removing the battery from the main board and shorting the terminals in the battery carrier (bend up a paperclip so it sits on both terminals by its self), make sure the power is unpluged first, it will take about 1/2 hour to completely reset, then try to boot, if sucsessful the cmos will need to be setup again
good luck
terry
Posted on Feb 29, 2008
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
Apr 23, 2013 | Computers & Internet
Pc not booting
If you hear the CPU fan turn on that doesn't mean the CPU itself is working. It can be only that the motherboard is getting power. Check all your connections such as monitor and peripherals and re-connect them. If you still don't get P.O.S.T. or ANY letters or boot options on your screen then your CPU is dead. (unless your monitor is bad)
Another easy diagnostic is using your ears. For example the pitch sound of the fan in some motherboards tends to lower and then increase because it's reading of the hard drive. This means your CPU is ok but either your graphics connection is bad or your monitor is.
Apr 22, 2012 | Intel Motherboard
D915GAG MOTHERBOARD 2.93GZ P4 CPU CPU FAN SPINS MOTHERBOARD LED ON NO POST
Remove the cmos battery and install another ram .
Reply me soon
Feb 27, 2011 | Intel D915GAG Motherboard
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
NF7-S2 No POST on startup. Can Not get into Bios
In that case the motherboard itself is faulty replace it..
Jun 08, 2009 | Abit nForce2 NF7-S2 Motherboard
My Intel D101GGC Motherboard doesn't power up!
is it properly plugged in?
is you power supply fan working?
is your power supply working?
do you get any post bleeps?
is your cpu working?
are the leds on the motherboard(physically)or on the external case.if on the case then check the cable on the motherboard
these are some of the questions which will narroway down your problem
May 22, 2009 | Intel D101GGC Motherboard
Led pwr+hd isn on, cpu fan is runing, but no
if your monitor is working properlly,then you should check the following things:-Remove ram and start the computer. If it gives you any beep then your motherboard is all right.And if not,then it's time to buy a new motherboard.
Mar 17, 2009 | Gigabyte GA-8I848P-G Motherboard
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
I have a Boot Problem with my INTEL P4 3.0Ghz. 800Mhz FSB,1M L2 Cache, Socket 478 CPU
I have experienced something similar with my new Core2Duo processor and a fairly new Socket 775 processor. Troubleshooting it led me to believe the CPU simply wasn't compatible with the motherboard. Although it's a shot in the dark, I suggest that you try out some of the following: - Did you try pulling out the graphics card to see if you got it to POST then? The graphics card or the monitor may need replacing. - Did you remove the RAM? - Are you sure all cables are attached properly? - Try to take out the CPU, talk to a friend with a socket 478 motherboard and replace his CPU with your CPU. Does it work now? If yes, motherboard needs to be replaced.
Nov 12, 2006 | Intel P4 Prescott CPU 2.8A Ghz W/1MB CACHE...
DFI 865PE INFINITY P4/A&GB L&R/1394/ATX Motherboard Logo
186 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
jason
RajDeep Gautam
RajDeep Gautam
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
