Question about Husqvarna Viking 1
Viking sewing machine
Plugged in machine and turned it on. The light flickered, but then there was no power. Think it's a short? Thanks
This will happen if you wind your bobbin at full speed. The thread wraps around the center of the bobbin too tightly and causes it to close tight around the winder. Most times if you take off part of the thread you can get it off. But you can prevent this from happening next time by winding more slowly.
Posted on May 30, 2008
My Viking Rose bobbin winder wont release my bobbin. This is the second time this has happened with the same bobbin, and I got it off the first time by gently manipulating the bobbin. It was full of thread so I decided to use it and then dispose of the empty bobbin. Well, you can imagine what happened! When it was empty, I, of course, forgot and put it right back on the winder. What do I do?
Posted on Mar 14, 2008
What does it mean when it says main motor overload please wait
If it's a Huskylock Serger it means the machine is in a "bind," possibly think fabric, etc. The motor is "overloaded" and shuts down. If it continues after serving for a short time on normal fabric the motor needs to be rebuilt or replaced. See a local Viking Service Tech for repair or motor replacement.
If it is a Sewing/Embroidery Machine it may still be an issue with the motor but could also be the main control board or power supply. Again see a local Viking Service tech for repair.
Apr 14, 2015 | Husqvarna Viking 1
Husqvarna sewing machine - viking 400
HI,
Do you mean how to retime it?
Jun 11, 2008 | Husqvarna Viking 1
Viking 990S turns on and then shuts down right away any ideas of what I might do?
the machine may have powersupply or other electrical/ electronic problems. Take it to an authorized Viking repair dealer to discuss repair/ replacement options.
May 04, 2014 | Husqvarna Sewing Machines
Problem with Viking Scandinavia 400 embroidery machine
it's possible that part of the computer is mal-functioning or going out
having the machine checked would tell what it is for sure
Mar 20, 2012 | Husqvarna Viking 1
I used the machine did some embroidery work, switched it off for the night and the next time the touch screen will not come on and remains dark - if I put my hand towards the side of the machine where the...
Hi Jayn.
First check to see if your Husqvarna is still under warranty. If so take it in to the dealer for service.
I just did a little research and found that a recall was issued for some Designer 1s for power supplies overheating. The information on that is found here....
http://www.yankeequilter.com/recall.htm
and here....
http://www.husqvarnaviking.com/us/CustomerNoticeFeb132006.pdf
For additional information, please contact Husqvarna Viking at (800) 446-2333 between 9:00 a.m. and 4:30 p.m. ET Monday through Friday.
It sounds as if you have gotten hit with an energy spike. I make sure I unplug all of my sewing machines at night for this reason. But let's try a few things.
You said that if you place your hand where the USB goes, it flickers. What happens when you grasp and gently wiggle the USB when it is plugged in? Does it still flicker? If it does it makes me think there is a short or bad ground and needs service by a qualified professional. (basically you are becoming the ground when you touch there.)
Is there any screen brightness adjustment knob that perhaps got moved, bumped or turned by curious little fingers?
I think your best bet considering the value of your machine is to take it in for servicing.
Mar 12, 2011 | Husqvarna Designer I
Viking Designer SE that sometimes will not turn completely on - the lights just flicker but no full start? Anyone have this problem or have solution that might work without taking the machine back to...
I am having the same problem with my SE. It recently started doing that. Sometimes it would come on, sometimes not - just flicker. I haven't been able to get it to turn on for 2 weeks now. I earn $ with my machine, so I am really upset! No Vik dealer around to get it fixed either...
Jan 18, 2011 | Husqvarna Designer I
I need to download a manual for a viking 330 model sewing machine
I don't think that Viking allows free downloads. I think that you have to buy one from them, either their site or at a Viking sewing center, ie JoAnn Fabrics
Sep 11, 2010 | Husqvarna Sewing Machines
Turned on a recently "inherited" Viking Sapphire 850 sewing machine. There was what sounded like a bobbin rolling around somehow inside the top of the machine....thread was unwionding through. I gently...
Ooops...it sounds like a board has gone bad. There must be something metal loose inside the machine to cause a short like that. You need to find an authorized Viking dealer to assist you. The boards have a 5 year warranty, maybe you will fit into that period. It's probably best no to mention that an object in the machine caused the problem.
Best wishes!
Aug 31, 2010 | Husqvarna Viking 1
My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
Mar 14, 2009 | Husqvarna Viking 1
Power won't stop - Husqvarna/Viking 3600
your foot controller is damaged and should be replaced.
Jun 02, 2008 | Husqvarna Viking 1
Sewing Machines Logo
196 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
