Amplified Speaker System CA-3080 On But No Sound
My speaker are connected correct, and are turning on, but not sounding. The mute is NOT on and they are still not sounding? I have Windows Vista is there an program I need to install in order for them to work correctly with Vista? HELP!
Thanks Kindly
  • Anonymous Feb 08, 2009
    black
  • 168 Answers
Do you have a walkman, mp3 player, or any other portable stereo that you can test out the speakers?
This would be the 1st thing I would try. Place the plug that you would have normally going to your computer, and place it in the ear jack of the portable stereo or mp3 player. If you have sound, then I would make sure that your plug is in the correct jack in the back of the computer. Usually, the color of the jack is Green but that isn't written in stone. Just look for the speaker out or "out" where the sound card is located.
Try that and see if you get anything.
Get back and let me know and we can go from there.
Good luck.
mac
Posted on Feb 29, 2008
  • Mac Gyver Feb 29, 2008
    Otherwise, I would make sure that your sound card driver is installed correctly. You might need to update the drivers, but usually Vista and XP handles that.
    I want to 1st confirm that the speakers do work.
    Get back to me.
    Mac.
How to Resolve No Sound on Windows Computer?
Ensure that you aren't muted. The Windows Sound icon is small, and it can be tough to see if you are muted or not. Click the Sound icon in the System Tray and then click the Speaker button in the pop-up that appears to toggle the mute
  • If you don't have a sound icon, then your sound drivers are likely not installed correctly.
Inspect the speaker or headphone connection to the computer. A bad connection is one of the most common causes of no sound, and is also one of the easiest to fix. Make sure that your speakers or headphones are plugged in completely, and that the cables and connectors aren't damaged.
Ensure that your speakers are connected to the right port. Make sure that your speakers are plugged into the correct port on the back of your computer. The green port is most commonly used for external speakers, while the orange and black ports are used for surround sound systems and subwoofers. The pink port is for microphones.
Make sure your speakers are powered and turned on. Many speakers require a power connection, and may need to be turned on in order to work. Check the volume controls on the speakers as well to make sure that they're turned up enough to hear.
Reconnect your HDMI cable. A common problem for HDMI users is that no sound comes out of the speakers that the HDMI cable is connected to. A simple fix for this is to unplug and then replug the HDMI cable, which should switch the default playback device to the HDMI device.
Oct 20, 2016 | Microsoft Computers & Internet
Have a new computer that now has windows 8.1, no sound is coming from speaker, S120 speaker system. Can I download something to resolve this?
Check the following;
  1. Speakers plugged into the correct jack
  2. Speakers receiving power
  3. Speakers Turned On
  4. Sound not turned all the way down in Mixer
  5. Sound Not Muted
Jan 04, 2015 | Computers & Internet
I HAVE NO SOUND I NEED TO INSTALL HARD WARE AND I DO NOT HAVE TEH CD??
what operating system are you using you can download lots of sound drivers from cnetdownload.com
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 27, 2011 | Cyber Acoustics CA-3080 Computer Speakers
Sound is not working
There are some possible reasons why the sound is not working. It could be the volume control is in "MUTE", or the right sound card is not selected in the volume properties, or the speaker is defective.
Here's what you need to do:
1. Try to connect an external 2-channeled PC speaker. The computer should recognize the speaker and the sound should be transferred to the PC speaker. If the sound works on the PC external speaker, then you know that the volume control is NOT in mute and the sound card is selected. It means also that the built-in speakers could be defective.
2. If the same problem occur after connecting an external PC speaker, check the volume control, and make sure that the "MUTE" box is not checked. Then adjust the master volume.
* If everything's properly configured, but there's still no sound, check the volume properties under the Control Panel. Be sure that the correct sound card driver is selected. If that did not help, try to re-install the sound card driver.
* And the last option, contact the manufacturer and have them fix it for you.
Thank you and good luck!
Jun 26, 2010 | Acer Aspire 5535-5050 Notebook
Connected Parrot Ck3100 in Toyota Rav4 with Alpine 5897 aftermarket head unit. Tapped the Parrot harness into the speaker wire between the Front driver side speaker and amp, per instructions and phone...
First, you will have to ensure that the vehicle doesn't have an amplified system build in it. Cause in that case the kit should use the two wires line in and line out and check behind the autoradio if you have the entries line in line out. (with this solution, no accessibility with the mute when you have the radio and you receive a call).
But the general idea is to ensure about the vehicle system build in it, cause with an amplified system, you have to avoid it to passing the sound directly to the speakers. (may be wires to wires or a specific harness which is taking acount of it).
Feb 27, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Only got sound threw 1 speaker, everything is connected correctly.
were did u get the drivers from my mate as i am in the same sh..
May 27, 2009 | Cyber Acoustics CA-5150 Computer Speakers
Simply no sound from PC
Check if you have plugged in the stereo pin to the right port on the PC.
Open sound control (in control panel) and check if the both speaker(main volume) and the wave volume sliders are not set to the lowest.
Apr 02, 2009 | Computers & Internet
The volume is too low on my computer speakers
Hi, Mark Here, see I can help.
The 1907 does not amplify your sound it will let you control the volume to some degree but not boost the incoming sound.
If you had amplified speakers b4 your sound card requires amplified speakers.
Best two options i can give is.
  1. If it is a desktop you can install a amplified sound card. Hook to monitor speaker.
  2. Unplug monitor speaker &use amplified speakers.
Just so you know laptops use internal amplified speakers. If you decide to install sound card make sure it is an amplified card.
Hope that fixed ya! know not the best news. Need more help comment back. Please Rate.
Good Luck!
Mar 28, 2009 | HP w1907 LCD Monitor
No sound from the CA speakers - but controls still work!
Hello there!
First things first!
Just reinstall the USB driver for this speakers, and enable sound on multimedia, NOT muted. pop up volume.
RMS speakers if problem continue.
1.0 usb?
2.0 usb?
Feb 18, 2008 | Cyber Acoustics Portable USB Powered...
185 people viewed this question
 Grubhead
Grubhead
