Question about Samsung CLX 3160fn All-In-One Printer
Underside of scanner bed needs cleaned
How do I access the underside of the samsung clx 3160fn color laser all in one scanner bed glass to clean it. It is fogged, I expect due to just heavy use.
    President:
  • 2,072 Answers
Start by taking the back cover off. Then the 2 side covers, being careful not to break the speaker wires.
There will be 2 screws holding the sanner into the machine, you need to remove them. Carefully disconnect the ribbon cable, remove the ground screw, and all the connectors to the scanner and document feeder. It will have to be popped backward to unlatch it from the frame.
Remove the document feeder, take notice how you remove the wires so you can route them properly when reassemling.
Remove the screws holding the control consol and the scanner together.
There also will be some plastic tabs holding it snapped together. Seperate the glass frame from the remainder of the scanner.
disasseble the scanner head carefully being cautious not to break the lamps so you can clean the mirrors. Then clean the underside of the glass.
Then in reerse order, taking your time, reasseble the machine. Make sure to route the wires properly and carefully.
A bit time consuming, but the scanner must be removed and disassembled to clean it.
Posted on Feb 29, 2008
Poor print quality on samsung scx-4521f
Clean the laser scanner window and the primary corona wire
on the drum unit.
Jan 22, 2014 | Samsung CLX 3160fn All-In-One Printer
The glass on my samsung clx3160fn has fogged up on the inside how do I clean it
I don,t really know to well this model but with some patience and screw drivers start by take apart the top of the printer scanner.If you are lucky to do it you can access the bottom of the glass.
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
How you unlock the scannerof the samsung CLX 3160fn
The lock is the light green, slide the lock towards the front to unlock the scanner.
Mar 20, 2010 | Samsung CLX 3160fn All-In-One Printer
Vertical line on page when scanning/faxing
Clean the scanner glass. You probably have some dirt or whiteout on it. Open up the top feeder and look at the narrow glass and you'll probably find it.
Mar 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Jan 14, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN All in One Printer
open the scanning unit. in scanning unit clean the mirrors.
Sep 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
Jan 04, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160fn color laser
the lock is on the underside of the scanner deck, you can see it through the glass.  Reach underneath and slide to unlock.
Dec 28, 2007 | Samsung Office Equipment & Supplies
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
313 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
