Question about Microwave Ovens
Electrolux microwave model number E305075FPSA
Ii replaced the capacitor in the above mentioned microwave but not sure how the wires plug back on do u have a wiring diagram or can u tell me how they go on
  • Microwave Ovens Master
  • 9,098 Answers
There will be one wire that will go to two and only two points: From the high voltage tap on the high voltage transformer to one terminal of the capacitor. There will be nothing else connected at either point of that wire.
The other terminal of the capacitor will have two or three wires connected to it. It will go to the FA terminal of the magnetron and to the non-ground side of the high voltage rectifier diode.
If you need further assistance, please feel free to contact me directly through the links at our site: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 02, 2008
We have code F84 coming up on our Electrolux microwave, wall oven. Seems to be affecting the microwave. Any ideas what might be going on?
The F84 code is a communication error between the user interface panel of the microwave and the main control board. This could be the result of a problem with the touch panel's interface board, the main control board or the wiring between them. (The wiring harness can come loose or have a bit of corrosion at the connectors.) The usual recommendation is to check the wiring at the interface board then replace the interface board first. If that doesn't solve the problem, you have to replace the control panel.
If you add a comment with the model number of the unit, I may be able to help you find the parts your unit needs.
I hope this helps.
Apr 09, 2017 | Electrolux Microwave Ovens
My Electrolux above oven convection microwave chimes are not working. Solution?
Hello friend, thank you for your post!
I understand that the chimes on your oven and microwave are not working. I would be happy to help you locate any additional information regarding the chimes. In order to assist you further I would need to have your model number. You can locate the serial tag (which lists your model number) on the inside wall of your microwave or on the door frame. Once I have that information I would be happy to assist you. -Matt
Dec 19, 2015 | Electrolux Microwave Ovens
Whirlpool microwave fuse has blown multiple times
It depends on which fuse and when it blows. Wish you had mentioned that.
But usually it's a defective door switch or door switch mount.
If the fuse blows at random times while it's cooking, it may just be a loose fuse holder. Those have to be replaced due to metal fatigue, not just squeezed tight with pliers.
If it blows as soon as you hit "Start" to begin cooking, you have a shorting high voltage capacitor.
If it blows when you open or close the door, you have a loose or defective door switch or latch.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Nov 21, 2012 | Microwave Ovens
E305075FPSA HighSpeed Eletrolux the door appears to not be closing tight.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
Mar 22, 2012 | Electrolux ICON Microwave Combination Oven
Could a blown fuse cause a microwave to not heat, fan not turn and turnable not rotate
Not likely. More likely it's a bad door switch or door switch mount.
On Sharps and those made by Sharp (Dacor, Wolf, Viking, Electrolux, etc.) it's usually the bottom door switch.
See this handy help file on door switches.
If you need further help, please reply back or post a new help request which includes your full model number and the symptoms you mentioned above.
Dec 15, 2011 | Jenn-Air Microwave Ovens
I have a GE SpacemakerXL model JVM1350BW. It does does heat uo. The interior light, surface light,fan,clock,timer all work normallly. When I hit start, the time starts going down but the ovn does not turn...
Sound like a magnetron go to bad; here are the steps we took to replace it
Warning: You are not an electrician or repairman, following steps are from my experience. You should be careful while handling capacitor and other parts.
Unplug Microwave at least few hours before
Remove Microwave from above oven range by somebody holding Microwave from ground unscrew the screws from cabinet
Remove top cover of Microwave
Make sure to keep screws correctly in a place you remember what goes where
Make sure capacitor is discharged, GE manual inside Microwave says capacitor will discharge within 30 seconds once it is off. As a precaution check the voltage in capacitor to make sure there is no electricity
Remove other panels around magnetron part
You need to remove lot of connecting wires, should be careful to note down what goes where
If possible take digital photos to refer back when you put everything back together
You may need to remove transformer to easily remove and replace Magnetron. If you can't remove Magnetron easily then remove bottom panel of the Microwave and remove transformer
Now it should be easy to remove magnetron
Replace new magnetron and screw it. We had to put one outside part from old magnetron to new one because new one was missing that. Check to make sure both old and new one are exactly the same
Make sure put all wires properly back
Now put transformer back and screw it
Put capacitor panel in place and screw it
This might be a good time to test the Microwave to make sure it works fine now
Now cover the top panels and start to screw everything
Once everything assembled put the Microwave back above range put screws from top
Microwave Front and inside
Magnetron and transformer
Magnetron cover
Hope this helps (remember to rating this free answer).
Oct 10, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
Won't heat any foods.
you have a problem with your magnetron tube, and when the magnetron tube goes bad, the diode almost always goes out with it. you should be able to order a replacement tube from your manufacturers website, if you cant let me know and ill try to help you more.
here are the steps to replace the magnetron tube, if you want to do it yourself that is. if you have a professional do it, it can be pretty costly.
  1. Unplug Microwave at least few hours before
  2. Remove Microwave from above oven range by somebody holding Microwave from ground unscrew the screws from cabinet
  3. Remove top cover of Microwave
  4. Make sure to keep screws correctly in a place you remember what goes where
  5. Make sure capacitor is discharged, GE manual inside Microwave says capacitor will discharge within 30 seconds once it is off. As a precaution check the voltage in capacitor to make sure there is no electricity
  6. Remove other panels around magnetron part
  7. You need to remove lot of connecting wires, should be careful to note down what goes where
  8. If possible take digital photos to refer back when you put everything back together
  9. You may need to remove transformer to easily remove and replace Magnetron. If you can't remove Magnetron easily then remove bottom panel of the Microwave and remove transformer
  10. Now it should be easy to remove magnetron
  11. Replace new magnetron and screw it. We had to put one outside part from old magnetron to new one because new one was missing that. Check to make sure both old and new one are exactly the same
  12. Make sure put all wires properly back
  13. Now put transformer back and screw it
  14. Put capacitor panel in place and screw it
  15. This might be a good time to test the Microwave to make sure it works fine now
  16. Now cover the top panels and start to screw everything
  17. Once everything assembled put the Microwave back above range put screws from top
Dec 07, 2010 | Whirlpool MH7140XF Microwave Oven
I have a GE Spacemaker Microwave, Model # JVM165OCB006 Serial # TF900232B Manufactured 10/2003. Runs,turntable,light,timer etc but will not heat. Is it worth fixing?
it is mostly fault of magnetron tube inside Microwave. ge has a 10 year warrenty on this part and they can fix it for you for 200$ OR you can order the part from the web and install it yourself. when the magnetron goes out, the diode almost always goes out too so you'll need another of those too. so if you dont want to replace these then buy a new one if not the the steps to repairing are:
Dec 05, 2010 | GE Microwave Ovens
I have a GE Spacemaker and it is about 9 yrs. old. Sometines it heats; other times it doesn't. I change settings and sometimes that works. Is this something that can be repaired or is this a sign I need...
When the microwave is not heating, that means the magnetron is not working. This is what provides the heat to the microwave. I do believe the magnetron has a 10 year warranty.
If you wish to replace it, here is how:
Sep 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Newly installed GE profile pem31 microwave starts as soon as plugged in and won't clear or shut off with the key pad. It is not heating but light is on and making noise.
hello,
this is a simple function that you should be able to carry out your self
from the statement above this means that your oven maize have disconnect from the element position i.e the wire have been disconnected from the heater
what you need to do is that unscrew your microwave trace the wire to the heater you will surely fine were the wire is been disconnected from the heater
then you have to huck up the wire back to the element (heater) the wire mention above will be in red and others can be in different color
please when doing make sure that all form of power supply is disconnect from the microwave to avoid accident
thank you and thanks for using fixya.
May 02, 2010 | GE Profile Spacemaker II PEM31 Microwave...
Microwave Ovens Logo
555 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
